Author Topic: C5 Wall Bracket  (Read 5818 times)
C5 Wall Bracket
« on: 03, January, 2011 - 13:48:45 »
Hi all, some of you have asked about my C5 wall bracket that I have made for my C5.
You need to get some 'Uni-strut' that can be purchase from most main electrical distributors or from a electrical / mechanical contractor. Uni-strut comes in two forms either slotted or plain, I had used plain (just because I got it free from a friend).
You will require to cut four lengths (2 x 500mm, 1 x 650mm (front-end of C5) & 1 x 750mm (rear-end of C5)). Also required will be 2 x 90 degree angles, 8 x zebs (spring type square nuts), 8 x washers, 8 x 28mm hex head bolts & 6 x end caps (black or white). To fix the brackets to the wall you will require suitable anchor bolts (I have used 6 x @ top, middle & bottom locations).
Please see below photos for reference.
I hope this helps Lance.
« Last Edit: 03, January, 2011 - 13:54:53 by Lancealot »
Offline vanpeebles
Re: C5 Wall Bracket
« Reply #1 on: 03, January, 2011 - 14:18:51 »
Hahaha! I thought that was a motorcycle lift and the poles in the background were the struts!
Re: C5 Wall Bracket
« Reply #2 on: 04, January, 2011 - 07:21:35 »
Great, thanks for that info, another to do job for me, looks a great way of keeping your C5 up safe and out of harms way.
Re: C5 Wall Bracket
« Reply #3 on: 04, January, 2011 - 16:31:16 »
with a couple of extentions, could make it a nice working platform to
Alan
Offline gowrings c5
Re: C5 Wall Bracket
« Reply #4 on: 04, January, 2011 - 19:50:50 »
thanks. thats really appreciated. i hope your design gets saved somewhere on this site for future reference. brilliant work!! im gonna build this before the bike pedals and lawnmowers attack in the summer.
Re: C5 Wall Bracket
« Reply #6 on: 05, January, 2011 - 13:21:06 »
Looks nice, I made mine out of wood. ( Platform )
I even have a lift installed to get it up there.
If I would have known off this construction before building my construction, it would be much more simpler. :-\
