Author Topic: I Finally Got One  (Read 20072 times)
Re: I Finally Got One
« Reply #45 on: 30, October, 2012 - 22:50:54 »
Hi Simon,
is your battery an original C5 issue?
« Reply #46 on: 30, October, 2012 - 23:03:29 »
Hello
Yes I am presuming it's the one supplied with it from new.
I don't think the C5 has been used very much at all.  Obviously the battery was dry when I got it and I just topped it up and charged it.
It did charge and it did run for a while but not for long and I think power was dropping as it wouldn't pull up even the slightest of inclines.
Within minutes the battery indicator was on red and if it rested for a couple of minutes would go back in the green.  But then back to the red in a matter of yards.
I didn't think it would be useable really.
I am keen to keep the original look of the C5 as it is in very original looking shape.  That is why I am keen if possible to use the key switch.
Chas has informed me that if I use a different battery I can get a better range. I guess I need to work out the pros and cons of each available option.
The way I see it at the mo is that if I use the original battery I can't go far, so have to change it.
If I keep the key switch I have to use a specific battery that has a good range but not great.  The benefit is that I can keep the key switch and keep it original and slightly more secure. Oh I also run the risk of frying the control box as its easy to get the connectors mixed up.
If I fit the C5 alive wiring kit which I have I can use any battery of any type as long as it fits in the space.  I can't fry the control box as it has protection built in.  It will have better range but the cons are that I can't keep the key switch and it's a bit less secure. If I went down this route then I have no idea which battery to purchase.
Am I right?
Simon
« Last Edit: 31, October, 2012 - 01:50:59 by pso-buzz »
« Reply #47 on: 30, October, 2012 - 23:27:19 »
Hi Simon,
are you technically orientated in electrical procedures?
« Reply #48 on: 31, October, 2012 - 01:37:42 »
Hi Karl.
No not really!
Simon
« Reply #49 on: 31, October, 2012 - 07:06:03 »
Hi Simon - your understanding of the wiring kit opposed to the original battery top is pretty much correct - it is however pretty easy to add a key switch into the circuit of the c5alive wiring kit so you can then have the best of both worlds if you are wanting some more security  :) :)
« Reply #50 on: 31, October, 2012 - 09:47:50 »
The type 49 45Ah battery gives a reasonable range for low cost and fits under the battery top plate if used with Ford Transit type terminal connectors
« Reply #51 on: 31, October, 2012 - 19:30:14 »
Coverman. What are transit type connectors and where can you buy them?
Cheers
Simon
« Reply #52 on: 31, October, 2012 - 19:35:56 »
Cheers
Simon
..these do the job : http://c5alive.co.uk/index.php?com=shop&display=product&id=36
« Reply #53 on: 31, October, 2012 - 20:00:41 »
Cheers
Simon
Excellent thank you Coverman.
What brand do you think is best?
Also is the type of battery the 49 the physical size?
Simon
« Reply #54 on: 14, November, 2012 - 17:46:31 »
It looks great 8) 8) 8) 8)
« Reply #55 on: 16, November, 2012 - 09:25:01 »
Yes the type 49 defines dimensions and terminal type and possition.The Transit battery terminals are used on Ford Transits apparently(which series I know not) and I bought them for about £8/pair from my battery supplier.(SYBS)
« Reply #56 on: 17, November, 2012 - 09:41:34 »
Very nice looking C5  ;)
« Reply #57 on: 23, February, 2013 - 12:57:55 »
Just a quick update to show the progress so far of the extras I have been collecting.  Just need to wire up the indicators.
(Oh and find a seat foam!)
There is only a C5 in the garden!!!
Offline danny7147
  • Battery level: 10
    • Bikes To The Future
« Reply #58 on: 23, February, 2013 - 13:06:17 »
Very nice! Like the garden too... ours is concreted lil ::)
« Reply #59 on: 23, February, 2013 - 14:06:04 »
Thanks Danny. The garden is a wreck at the mo after the winter.
