Author Topic: I Finally Got One  (Read 19275 times)
Re: I Finally Got One
« Reply #15 on: 19, October, 2012 - 20:19:58 »
Thank you.
I do have a small problem.  The pod doesn't always work but if I push the red connector in the back it lights up.
What is the correct procedure for cleaning this up or replacing it?
Simon
« Reply #16 on: 19, October, 2012 - 22:15:08 »
Hi there Simon what I do is to use some emery cloth on the contacts pins . Then spray a little contact cleaner in the cable connector and on the pins... bye Chas
« Reply #17 on: 27, October, 2012 - 17:42:28 »
Hello All
I have just taken the C5 out for it's first test run.
Here is a Vid:
http://www.youtube.com/watch?v=CuYzLaJN5Qg&feature=plcp
Hope you like it
Simon
« Reply #18 on: 28, October, 2012 - 20:43:10 »
Nice looking C5, good video.
« Reply #19 on: 29, October, 2012 - 15:21:36 »
Hey thanks Lance
Thanks also for the chat we had prior to me purchasing one.  I took as much advice as I could and made sure all the important items were included.
If I can find a way of transporting it to Heaton Park maybe we could meet up for a spin one weekend.
Thank you
Simon
« Last Edit: 29, October, 2012 - 15:26:20 by pso-buzz »
« Reply #20 on: 29, October, 2012 - 15:24:44 »
Hello All
Right I have got my C5 into the position I need to store it in. I know its probably not ideal but it's the best I can do with the space I have.
Can anyone tell me if I am going to do any damage to it, is anything going to de-form or mis-shape. Its kind of resting on its boot on a door mat to stop it getting scratched.
Is this ok?
Simon
« Last Edit: 29, October, 2012 - 15:33:13 by pso-buzz »
« Reply #21 on: 29, October, 2012 - 16:13:17 »
Hi Simon,
whatever you do always remove the battery when parking in this position, unless you happen to have a 100% sealed battery. If the battery is not sealed you can expect a heap of trouble.  :o :o
Regards.  KarlG.
« Reply #22 on: 29, October, 2012 - 16:35:50 »
I second what Karl has just said.
You shouldn't experience any problems with parking it like that as long as the battery is removed, unelss of course it is a 100% sealed one.
« Reply #23 on: 29, October, 2012 - 16:54:46 »
Thank you
Battery is definitely removed!
Simon
« Reply #24 on: 29, October, 2012 - 17:09:01 »
Hi there it looks great I don't think you will have any problems with the C5 as it is
But watch out for the chair falling down on the C5 ...bye Chas  :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :)
« Last Edit: 29, October, 2012 - 17:43:52 by C5 ENTHUSIAST + RESTORER »
« Reply #25 on: 29, October, 2012 - 21:21:40 »
Hey Chas you're slowing down theses days, it took you from 9:52 till 6:37 to figure that one out.  8) 8)
« Reply #26 on: 29, October, 2012 - 21:51:31 »
Not as good as my racking but a good idea!!!!!!!!!!!!!!!!!!!!1
« Reply #27 on: 29, October, 2012 - 22:27:59 »
I know it's not as good as your racking lance but I just don't have room!
« Reply #28 on: 30, October, 2012 - 12:51:04 »
So mate when you up for a C5 run at Heaton Park then!!!!!!!!!!!!!!
« Reply #29 on: 30, October, 2012 - 13:22:22 »
Hiya Lance
Not to sure, I have a few problems to overcome first!
I am still running on the original tyres, I don't think they have been used much but are so old I am not sure they are safe??  I am debating buying some of the city jets before they go out of stock.
I am running on the original battery, not sure it will have a range to get around Heaton Park, I have a C5 Alive wiring kit but I am wondering if I should keep the key switch and buy a compatible battery.  If I do this I am not sure how the plastic cover fits as the original battery has screwed bars coming out of the terminals.
I am not confident to ride the C5 on the roads yet to Heaton Park and I don't have a car that it will fit in!
Also I think I need to grease everything before a big run, when I go around  right hand corner I get a squeaking noise, I am presuming that the bearings need greasing on the off side wheel?
I am not sure if I should just go for the strip down and re-grease everything after painting the frame and building back up.
Any help on any of the above is always welcome from anyone!!
Simon
