Author Topic: Fuses for the C5, should they slow blow or normal?  (Read 2178 times)
joggaeco
« on: 21, October, 2011 - 01:36:06 »
Hi! All,
I was in a quandry about this, so I replaced them with normal fuses to be on the same side.  For an  ebike I had, the fuses had to be slow blow.
Whats the case for the C5?
Many thanks,
Joggaeco
Re: Fuses for the C5, should they slow blow or normal?
« Reply #1 on: 21, October, 2011 - 16:03:00 »
I don't think the original fuses were slow blow - the amount of circuit board damage i have seen i think your choice of 'normal' fuses is the correct one ! :)
joggaeco
« Reply #2 on: 21, October, 2011 - 20:37:08 »
Thanks! I bought those, just in case!
 That's put my mind at ease.
Just a tip, I always carry some with me, shame to spoil a run, juts becuse of a fuse.
« Reply #3 on: 22, October, 2011 - 03:20:07 »
If a fuse blows there is normaly a reason that will need attention  8)
« Reply #4 on: 22, October, 2011 - 09:45:27 »
Hi, I agree with POD11 you have an issue somewhere. Good luck with the fixing.
