Author Topic: Latest restoration for Mark  (Read 14940 times)
Re: Latest restoration for Mark
« Reply #15 on: 15, August, 2013 - 19:47:24 »
« Last Edit: 15, August, 2013 - 19:52:29 by C5 ENTHUSIAST + RESTORER »
« Reply #16 on: 15, August, 2013 - 19:53:58 »
Ok look what an hour can do .Replaced all three small cogs + the outer gearbox case and the inner gearbox part ....And did a little clearning ...
And here we are finnished and tested running great ...That's it for today keep looking more on Friday ?????????????
« Last Edit: 15, August, 2013 - 20:03:41 by C5 ENTHUSIAST + RESTORER »
« Reply #17 on: 15, August, 2013 - 22:26:16 »
You always do a great job Chas, always enjoy looking at yout pictures of progress  :)
Retrp Andy.
« Reply #18 on: 16, August, 2013 - 07:53:52 »
Thanks Andy ...
« Reply #19 on: 16, August, 2013 - 09:23:45 »
Hi you can leave all the wiring and the items you have asked about .But I would take of the Pod and control box off if you are going to hose it down unless you seal them in  plastic bags .
Thank you very much for this Chas.  My C5 is very clean so won't need hosing.  This makes the task of cleaning up the chassis much less daunting.
Cheers
Simon
« Last Edit: 16, August, 2013 - 09:33:21 by pso-buzz »
« Reply #20 on: 16, August, 2013 - 19:34:42 »
Ok great ..Here how I got on today ..Starting with the Chassis that I started yesterday ..
New tyres /brake cables/bearings Chain tenisioner
As you can see I have fitted a motor and the large drive cog ,But what you cannot see is that I have fitted a 12 tooth cog on the motor and  the large drive cog has 72 teeth instead of 68 ..So what happens is that it will only drive at aprox 6/7 MPH ...But it will need to be taken out for a good run when completed .This is just a temperry thing to see if the C5 will go slow enough and the power will be more for  Mhurt
« Last Edit: 16, August, 2013 - 20:16:34 by C5 ENTHUSIAST + RESTORER »
« Reply #21 on: 16, August, 2013 - 20:44:52 »
Look like it isn't just my C5's gearbox cracking due to age, as always, great progress Chas.
« Reply #22 on: 18, August, 2013 - 11:51:42 »
Yes they are getting old now...
Anyway here is afew more photos
Here comes the body
Looking good
« Last Edit: 18, August, 2013 - 12:13:37 by C5 ENTHUSIAST + RESTORER »
« Reply #23 on: 19, August, 2013 - 06:25:50 »
Very nice, almost done  :)
« Reply #24 on: 19, August, 2013 - 11:36:35 »
Very nice and tidy wiring Chas
Offline mhurt
« Reply #25 on: 20, August, 2013 - 18:35:17 »
Looking good as always, makes me ashamed of mine :)
« Reply #26 on: 20, August, 2013 - 20:03:07 »
Hi all they need to do is run ...
Anyway here is a photo of the wheel trims to be fitted...(Excuse the feet as they got in the way) :) ;) :D
Not a lot to do now before the test run
« Last Edit: 20, August, 2013 - 20:07:16 by C5 ENTHUSIAST + RESTORER »
« Reply #27 on: 21, August, 2013 - 21:10:20 »
Hi there  Mark just trying out Flicker due to running out of space on Photobucket .
Anyway here are some of the photos of your C5 compleated but for a run out ..And then change the motor and large cog for the original one's
3-IMGP3734 by CHAS SINCLAIR C5 RESTORER, on Flickr
6-IMGP3737 by CHAS SINCLAIR C5 RESTORER, on Flickr
5-IMGP3736 by CHAS SINCLAIR C5 RESTORER, on Flickr
4-IMGP3735 by CHAS SINCLAIR C5 RESTORER, on Flickr
2-IMGP3733 by CHAS SINCLAIR C5 RESTORER, on Flickr
« Last Edit: 22, August, 2013 - 21:29:24 by C5 ENTHUSIAST + RESTORER »
« Reply #28 on: 23, August, 2013 - 18:19:17 »
Very nice
« Reply #29 on: 23, August, 2013 - 21:43:27 »
Thanks .Just fitted a new front light .The old one had a piece broken off ...
