Author Topic: Gearbox removal  (Read 3436 times)
Gearbox removal
« on: 01, July, 2010 - 18:06:22 »
Looking at my c5alive email queries, gearbox removal is always a favourite question.So a link to this topic will be used  to make my reply faster (and easier  :))
Having first removed the combined motor & gearbox assembly from the c5, I gently lift the "fingers" using a screwdriver and insert cable ties  on their side to keep the fingers raised;
I then grab my pliers/grips and pull the gearbox away from the motor. You must be careful here and pull in a straight line - otherwise you risk damaging the gearbox housing;
The gearbox cogs just lift off the end of the armature.
To further dismantle the assembly, remove the two bolts that secure the fingers to the motor housing ( please note - they are still in place in the photo !) ,and then slide a mallet/hammer along the motor body to ease the fingers off;
Dismantling the Motor assembly is covered in another topic;
I'm not saying this is the only, or even the best, method to do this - but it works for me. Hope the info helps  ;)
« Last Edit: 01, July, 2010 - 18:10:03 by BooBoo »
Re: Gearbox removal
« Reply #1 on: 12, July, 2010 - 03:13:33 »
I use small nails ...
Then Pull off with pliers
Just another way of doing it .......    ;)
Re: Gearbox removal
« Reply #2 on: 12, July, 2010 - 09:33:28 »
I've also heard of someone using a large jubilee clip and winding it out (as opposed to tightening it) not tried that myself yet. :-\
Although all these methods work, it would still be cool to get hold of the genuine Sinclair tool made for the job - just like the one Adam has  8)
Re: Gearbox removal
« Reply #3 on: 12, July, 2010 - 13:14:45 »
Blimey...
I didn't know they did one, bit of a collectors item i would think.
There is always ways around these things but sometimes it is nice to have the right tools for the job. I have a Raleigh Chopper MK2 and to remove the stand from that is just as bad, but with the right tool it takes seconds, rather that hours and a few scraped knuckles.
