Author Topic: pod control box problem  (Read 2450 times)
marcdonnelly
« on: 14, August, 2010 - 09:19:34 »
Can any one advise me both me c5s  have the same problem put the fully charged battery on and 2miles later on one and 1 mile later on the other beep beep the battery is flat ..put battery on charge i hour later full .so we know really the battery was not flat or it would take 6-8 hours im running with orignal sinclair tops.what has gone wrong in the control box i wonder im sure the pods are ok.
Re: pod control box problem
« Reply #1 on: 14, August, 2010 - 09:46:58 »
Not quite sure on that one - just to be double sure it's not the battery only charging certain 'cells' do you have another battery (or borrow one) to try ?
marcdonnelly
« Reply #2 on: 14, August, 2010 - 10:13:27 »
hi marty plumber is back from holiday sunday and i will see if i can use one of his batteries im pretty sure the batteries are ok there not that old and have not been recharged that many times but i will take your advice to rule that problem out...
