Author Topic: Chain Tensioner Retaining Clip  (Read 4167 times)
« on: 27, September, 2012 - 18:44:07 »
At last, the first four of my many questions.  :)
On the C5 that I've just aquired the chain tensioner retaining clip is missing, the tensioner is held in place with a piece of foam padding. Needless to say the tensioner doesn't function as it should.
1. Are these clips still available?
2, If yes, where can I obtain one?
3. If no, has anyone a spare that they are prerared to sell?
4. Should there be nothing available, can anyone supply me with an accurate drawing of the clip whereby I can make one?
So here's hoping for all of your positive answers.  ::)
KarlG.
Re: Chain Tensioner Retaining Clip
« Reply #1 on: 27, September, 2012 - 18:52:47 »
Hi there Karl there are two plastic items on the tensioner which one is missing ....Chas
« Reply #2 on: 27, September, 2012 - 19:25:18 »
Hi Chas,
there is a white plasic part fitted to the tensioner arm, so I assume there there must be a clip that attaches to the chassis. The part I'm looking for is for the chassis.
Regards. Karl.
Offline Pep
« Reply #3 on: 28, September, 2012 - 16:07:18 »
My C5 was missing this part too, you are welcome to the one I made as a temp until you can source the original, perhaps this is another part that MikeDX could produce with his 3D printer, I would buy some for spares
« Reply #4 on: 28, September, 2012 - 19:41:14 »
Hi Pep,
many thanks for your kind offer.
There's no rush, bike won't be on the road until spring next year, plus I'm on the other side of the ditch.
I have no idea what the thing looks like, were it's located etc. In The Parts List it's shown as a black dot, I can make a black dot, but I'm shure it's not going to work.  :D Even a photo of the item in situ (unobstucted by the tensioner) would do.
Cheers. Karl.
« Reply #5 on: 28, September, 2012 - 21:16:51 »
Hi there Look at my section on the site (The Chas section and you will see a few items I have made including the chain tensioner)
« Reply #6 on: 28, September, 2012 - 21:55:09 »
Ok olé!
Hi Chas,
found the info the I need. Thanks for the tip.
Regards.  KarlG.
« Last Edit: 28, September, 2012 - 22:50:12 by KarlG »
« Reply #8 on: 29, September, 2012 - 20:49:45 »
Hi Plod,
these are the new units from Chas, he pointed out that the mounting is not compatible to the oringinal. I have an original.
I now know how the original was mounted, so I can make my own unit.  8)
Anyway thanks for trying to help.
Cheers. KarlG.
