Author Topic: Found my boot clip  (Read 4772 times)
Found my boot clip
« on: 18, November, 2012 - 09:18:25 »
What a find, I lost one of my boot securing clips when on the Royal Run route last year and got a replacement, and I have been running about 3 miles along this route 2 or 3 times a week since July trying to loose a few pounds and get a little fitter, and to my amazement I found it right in the middle of the path after the grass had been cut along the edges, and its not damaged, so I now have a spare  :)
Re: Found my boot clip
« Reply #1 on: 18, November, 2012 - 13:54:40 »
Wow Andy that was a lucky find - on a level with Minidaz finding his chain link !!!   :) :)
« Reply #2 on: 18, November, 2012 - 20:19:06 »
What are the chances in that  ::)
1 in a 1,000,000 :P
« Reply #3 on: 19, November, 2012 - 10:08:21 »
Your luck is in matie ...go out and buy that winning lottery ticket  :P
« Reply #4 on: 19, November, 2012 - 12:25:51 »
Only to lose it, :o :o  then find it again after the claim limitation. 8) 8)
« Last Edit: 19, November, 2012 - 12:29:58 by KarlG »
« Reply #5 on: 19, November, 2012 - 17:42:22 »
We did !!!  :) :) :)  But did'nt even get one number  :'(
« Reply #6 on: 19, November, 2012 - 18:43:46 »
You should be ashamed of yourself.  :P
« Reply #7 on: 19, November, 2012 - 18:45:36 »
You never do with the lottery >:( >:(
Offline mhurt
« Reply #8 on: 19, November, 2012 - 19:28:03 »
Want to pop over here and try your luck at finding the little plastic & rubber grommet  from the mast hole that I lost? :p
« Reply #9 on: 19, November, 2012 - 19:32:34 »
When was this ???
« Reply #10 on: 19, November, 2012 - 19:34:08 »
Andy could lose some more weight running around the area you lost it  :D :D
« Reply #11 on: 20, November, 2012 - 06:38:46 »
I'm only half way to my goal weight and not been running for a few weeks as had man flu, its been raining or other things, I do like a short run on a cold frosty morning (I never though I was someone who would enjoy running, but when the weight starts to come off you enjoy the results) two stone almost lost and two to go.
« Reply #12 on: 23, November, 2012 - 12:13:05 »
That's one way to make your c5 go faster.. ;)
Offline mhurt
« Reply #13 on: 23, November, 2012 - 12:28:11 »
Hairy Dieters Cookbook, that's all you need :)
I lost 4.5st in 2 years but couldnt shift the last stone. 6 weeks on that diet and I lost it, and it's real food, not rabbit food :p
Can't say it's helped me go any faster or uphill any easier though :D
« Reply #14 on: 23, November, 2012 - 16:33:16 »
Oh well at least your are skinnier  :)
