C5 Help => TECH TIPS from C5Martin => Topic started by: c5martin on 21, September, 2008 - 21:45:36
Title: Handle bar stem removal
Post by: c5martin on 21, September, 2008 - 21:45:36
Undo Bolt on top of handlebars - dont undo entirely (if it does come off entirely re-attach with a couple of turns)
Take a non marking rubber hammer and tap on the stem to release the conical wedge
Undo Stem bolt fully
Retract Stem bolt
Collect Conical wedge from floor under the body
If it wont budge - lay C5 on its side - attach the stem bolt to wedge from the underside and screw in stem and then use stem to pull the wedge out.
Remove handlebar from C5 by pulling whilst twisting from above.
Title: Re: Handle bar stem removal
Post by: Karl on 23, August, 2009 - 15:08:15
In addition, check this link for the "hold and twist" method - may help with stubborn stems  ;D
 http://c5alive.co.uk/forum/index.php?topic=626.0
Post by: Karl on 26, June, 2010 - 15:12:46
Note: ensure all the bolts and fittings are removed as in c5martins first post BEFORE trying this !  This is in addition to Martins advice and assumes you have already completed those steps..
Some times the "hold and twist" method will not work, if the handle bar stem is seized then you may end up damaging the steering rod plate at the bottom.
When more brute force is required, I find this method works;
I use two socket set extension bars as a "drift" to hammer out the handle bar stem from underneath.
It's easier to do this if you place the c5 upside down - a "Black & Decker" workmate is ideal .
(http://i74.photobucket.com/albums/i257/1stbooboo/c5restoration2004.jpg)
(http://i74.photobucket.com/albums/i257/1stbooboo/c5restoration2005.jpg)
(http://i74.photobucket.com/albums/i257/1stbooboo/c5restoration2003.jpg)
(http://i74.photobucket.com/albums/i257/1stbooboo/c5restoration2006.jpg)
Having tried other methods with varying levels of success I find this way has worked without causing any chassis damage or any other snags on four handlebar stems so far - including a couple that were really rusted in. It's my preferred method for now until I discover an easier way  ;D
Post by: coverman on 28, June, 2010 - 11:16:51
For stubborn stems, why not soak the offending area overnight in Coca-Cola.?
Post by: Umpa on 28, June, 2010 - 18:22:13
I like a good soaking in vodka :)
Post by: TRminator on 26, September, 2010 - 00:39:05
I'm struggling with this one lads.  I'm quite simply confused and need further help.
C5MARTIN - you seem to describe attaching the stem bolt and pulling the threaded piece in the steering bearing carrier out from under the vehicle in the following excerpt from your post:-
"If it wont budge - lay C5 on its side - attach the stem bolt to wedge from the underside and screw in stem and then use stem to pull the wedge out."
But BooBoo' pics on the other hand seem to depict that same threaded item being driven up the way.  I've tried using the extensions and hammering up the way from underneath, but nothing budged and because of C5MARTINS piece quoted above I was reluctant to do so with much force in case I'd gotten the wrong end of the stick.
Sorry to be an idiot.
-Kyle
Post by: radiomarty on 26, September, 2010 - 04:46:32
Hi Kyle - C5Martin is reffering to a threaded nut that the stem bolt locates into which has to drop down and be removed before you can attept to place something inside to remove the stem upwards as Boo Boo is describing.Hope that makes sense  :D
Post by: Karl on 26, September, 2010 - 20:55:10
In my piccies the c5 is upside down sitting on a black and decker workmate - so you are hammering the handlebar stem from the underside so to speak  :)
Post by: TRminator on 28, September, 2010 - 16:38:33
Ah!  That coppery "ting" sound you are doubtless hearing is the penny dropping with me!
There's a stem bolt complete with wedged threaded thingy on eBay at the moment and from reading your reply radiomarty and looking at the pic I now see what I have to do.  Unfortunately I've been hammering the wedge deeper into the recess, so I could have a battle on my hands!
Cheers lads.
-Kyle
Post by: C5 ENTHUSIAST + RESTORER on 28, September, 2010 - 17:14:29
Theres is another way I sometimes use ...Is to cut the top off and hammer the bar  down from the top ...
the only thing when you get it out it will have to be welded back on ..The thing is if you don't get it out you are then in trouble .....the reason I use this way is that  where the taped bolt fits underneath goes on does not get damaged and you are not trying to push it all the way back ...(ps it does not always work )  bye Chas
Post by: Karl on 28, September, 2010 - 17:38:09
Cheers lads.
-Kyle
...oops, I guess I assumed you realised that the piccies are a follow on to c5martins advice and that his initial steps need to be followed first ,i.e. remove all the relevant components before grabbing the hammer  ;)
Post by: TRminator on 29, September, 2010 - 13:02:44
 :D To be honest BooBoo, if it wasn't for the minor point of not knowing that the tapered threaded thingy needs dropped out through the bottom before doing what you show in the photographs, your post would have been a big help.  In fact, the similar series of shots you did for removing the pedal crank and bracket were a massive help to me, so keep up the good work.
cheers fellas.
-Kyle
