Author Topic: Removing the back axle bearing  (Read 2213 times)
Offline Paul
« on: 22, June, 2013 - 21:14:10 »
Hi, I need to replace the back axle bearing on the brake side can anyone tell me how this is done?
Re: Removing the back axle bearing
« Reply #1 on: 22, June, 2013 - 21:19:11 »
Hi there Paul .You find that they are very hard to remove unless you know someone that has a bearing press ..I have just done one myself but could not wait untill Monday so I used a hammer on it but I would not recomend it ....
« Reply #2 on: 23, June, 2013 - 08:30:00 »
Hi -I use a puller pullet but as Chas says a bearing press is best if you know simeone with one
« Reply #3 on: 23, June, 2013 - 10:11:04 »
I get mine done at a local garage where my mate works, he uses a bearing press
Offline Paul
« Reply #4 on: 23, June, 2013 - 10:29:36 »
Hi, Thanks all for your help.... I'll put the hammer back and go around the local garages see if I can buy them a drink in return for the use of their press!
« Reply #5 on: 23, June, 2013 - 20:10:37 »
Hi don't forget You will have to go back to them to fit a new one when you replace the old one ...
