Author Topic: My restoration Pep  (Read 12046 times)
Offline Pep
My restoration Pep
« on: 30, September, 2013 - 19:36:12 »
Hi guy's
I have finally worked out how to upload photo's so here's a few of my restoration
Frame powder coated yellow/black
Rear disc brake
Motor cooling (after overheating first motor)
Front wheel disc brake
It's complete now and up and running on 24v, I am very pleased with the results, just minor alterations and some indicators to go !!
Re: My restoration Pep
« Reply #1 on: 30, September, 2013 - 19:43:38 »
Well done Pep it looks great ......Chas
Offline dansretropod
    • www.c5owners.com
« Reply #2 on: 30, September, 2013 - 19:54:37 »
Great job, very impressive.  Love the disc brakes, that sort of thing is way beyond my ability :-\
« Reply #3 on: 30, September, 2013 - 20:19:25 »
Fantastic job Pep - it was great see the transformation you had made to this vehicle over the year between Brooklands events.
Offline dadandjames
« Reply #4 on: 30, September, 2013 - 22:29:55 »
Nice  :) wish I had the time. :(
Offline Pep
« Reply #5 on: 01, October, 2013 - 01:42:49 »
Thanks guy's,
I have replaced a lot of the parts from the original C5 to get it in a condition were it should be around for a few more years.
A good challenge and a fun project to do, would def do it all again, thanks to the help from this site and everyone who helped along the way.
dave in hull
« Reply #6 on: 01, October, 2013 - 18:43:08 »
Nice work pep  can I ask where did you get the front wheel from?
Offline Pep
« Reply #7 on: 01, October, 2013 - 20:46:36 »
Hi Dave
I got the wheel from eBay for about £10 the hub was separate as was the disc.
I went to my local bike shop and asked them to fit the hub and balance the wheel, they almost agreed to do it but it was to small for their jig. They were very helpful in calculating the spoke length for each side though, one side were fine and the other needed to be reduced by 0.5mm, I ended up setting it up myself using some tie wraps attached to the forks & it seams to be ok.
Pep :)
« Reply #8 on: 03, October, 2013 - 21:58:06 »
Very nice, any more pictures ?
Offline wigan lad
« Reply #9 on: 04, October, 2013 - 20:44:38 »
Hi pep nice mod love it could do this on my 24v any chance of a photo of how the disc is fastened on the wheel plz
« Reply #10 on: 05, October, 2013 - 20:30:28 »
Would love to fit the same braking system to my 24 volt C5, is it possible to have some details and an up close look at how you did the rear brake mod.
Thanks John - PLOD11
Offline Pep
« Reply #11 on: 05, October, 2013 - 21:11:46 »
Hi Wigan Lad
The disc is fastened to the wheel with an aluminium centre,
Pic also shows the inner ball bearing, I used the original outer bearing due to lack of time, I plan to look at using a sealed ball bearing when I have more time, if it is possible
Before drilling and tapping for the disc
The rear of the aluminium and the inner wheel, cut down
The fixing
Another close up, shows the folds on the plate better, 45 deg fold on the front to add extra support
The plate is folded under the frame and is held with the frame bolts through the axel bearing housing, and two bolts through where the brake shoes were mounted. The bearing housing I trimmed the shroud off, you could just reverse it but I think trimming it makes a neat finish.
I will take some more pics tomorrow, but it looks like any other standard C5, I like to think of it like a wolf in sheep's clothing.
I am unable to fit the front wheel covers without cutting them, so I have another set of forks were I will mount the calliper on the rear and hopefully this will allow fitting of the covers without having to cut them.
Also thinking of adding more gears but recently moved house and will have to put some time in there soon, I will help with questions and post more pics if anyone wants to know more, watch this space !
PS the brake disc is held on with csk bolts allowing a closer fit to the plate, there is only a few mm clearance to play with.
Pep
« Reply #12 on: 06, October, 2013 - 11:49:54 »
Beautifully crafted mate, nice job  8)
Offline Pep
« Reply #13 on: 06, October, 2013 - 21:09:28 »
Thanks Booboo
Here's a couple of pics from earlier today.
This shows the plate mounting
Good news I've been out in the park today, bad news, cooked the motor, I need to get some temp warning !
Pep
« Reply #14 on: 10, October, 2013 - 20:48:56 »
Wow, that is looking very nice , great upgrades carried out  :)
