Author Topic: 1970'S AND 1980'S Cycle Extravaganza Aug 13th & 14th  (Read 13258 times)
Re: 1970'S AND 1980'S Cycle Extravaganza Aug 13th & 14th
« Reply #30 on: 16, August, 2011 - 14:56:38 »
Excellent piccies , looks like a lot of fun - a top runner for inclusion in next years events  8)
« Reply #31 on: 16, August, 2011 - 16:36:56 »
« Last Edit: 16, August, 2011 - 20:26:29 by PLOD11 »
« Reply #32 on: 17, August, 2011 - 05:56:51 »
Very Retro, Very Cool  :)
« Reply #33 on: 17, August, 2011 - 07:57:23 »
Looks like a gread day out. Great photos. Bad news with the control box, looks like a loose connection.
« Reply #34 on: 17, August, 2011 - 09:17:43 »
That was my initial thoughts Lance but on further investigation it turned out that the Negative motor power cable was routed over the top of the positive motor connection post - overtime the cable had become eroded and the insulation worn through causing a short out of the motor - worth checking. I always route this cable down and along the pod etc connections but unfortunately as this was brought full restored I hadn't really looked into it - lesson learn't ! Ps the control box was surprisingly not too bad and is now up and running again.
« Last Edit: 17, August, 2011 - 09:29:19 by radiomarty »
« Reply #35 on: 18, August, 2011 - 07:16:04 »
Marty - I must admit to having routed a few cables across the top myself so that is a useful observation. Didn't occur to me that over time the screw thread would chafe through the cable ..
Might be worth putting a new topic in the faults and solutions section so this valuable info isn't lost.
Think I'll give my fleet a quick check over !
« Reply #36 on: 18, August, 2011 - 11:14:35 »
Will do Karl - I will knock something up on the routing and the importance of regular checks that they are tight , :)
