Author Topic: C5 Wall Bracket  (Read 5987 times)
C5 Wall Bracket
« on: 03, January, 2011 - 13:48:45 »
Hi all, some of you have asked about my C5 wall bracket that I have made for my C5.
You need to get some 'Uni-strut' that can be purchase from most main electrical distributors or from a electrical / mechanical contractor. Uni-strut comes in two forms either slotted or plain, I had used plain (just because I got it free from a friend).
You will require to cut four lengths (2 x 500mm, 1 x 650mm (front-end of C5) & 1 x 750mm (rear-end of C5)). Also required will be 2 x 90 degree angles, 8 x zebs (spring type square nuts), 8 x washers, 8 x 28mm hex head bolts & 6 x end caps (black or white). To fix the brackets to the wall you will require suitable anchor bolts (I have used 6 x @ top, middle & bottom locations).
Please see below photos for reference.
I hope this helps Lance.
« Last Edit: 03, January, 2011 - 13:54:53 by Lancealot »
Offline vanpeebles
Re: C5 Wall Bracket
« Reply #1 on: 03, January, 2011 - 14:18:51 »
Hahaha! I thought that was a motorcycle lift and the poles in the background were the struts!
Re: C5 Wall Bracket
« Reply #2 on: 04, January, 2011 - 07:21:35 »
Great, thanks for that info, another to do job for me, looks a great way of keeping your C5 up safe and out of harms way.
Offline techytype
Re: C5 Wall Bracket
« Reply #3 on: 04, January, 2011 - 16:31:16 »
with a couple of extentions, could make it a nice working platform to
Alan
Offline gowrings c5
Re: C5 Wall Bracket
« Reply #4 on: 04, January, 2011 - 19:50:50 »
thanks. thats really appreciated. i hope your design gets saved somewhere on this site for future reference. brilliant work!! im gonna build this before the bike pedals and lawnmowers attack in the summer.
Offline frankev
Re: C5 Wall Bracket
« Reply #6 on: 05, January, 2011 - 13:21:06 »
Looks nice, I made mine out of wood. ( Platform )
I even have a lift installed to get it up there.
If I would have known off this construction before building my construction, it would be much more simpler. :-\
Frank
