Author Topic: Brand New (Some Original)Some used Sinclair C5 Spare Parts for Sale....Now!!  (Read 77709 times)
Hi there luke sorry the Motor has not arrived it was posted on the 19th at 14:46 .It should be with you very soon .If it has not arrived by Monday let me know and I will get onto the post office ...
Sorry Chas I just wanted an idea when it would get here, just as I clicked send this morning it arrived. I did not have time to send another reply because I had to go to school  ::)
Ok no problem thanks take your time fitting it ...(What are you doing with old one)
Well I am hopping to re-grease the old motor and keep it for a 'backup'
I am hopping to get the new motor on the C5 before the Crawly run on the 14th of April
I'll tell you how it runs when I fit it  ;) ;)
HI Chas - I need a set of frame plugs to hold the control box to the chassis - can you email details please Regards Marty
Hi there Marty I on holiday and will not be be back until the 24 of this month ,so in the mean time if you could  email me your full  address I will post you a couple ASAP
 .Bye for now Chas
Cheers Chas
Offline aceofhearts
Hi Chas,
Do you still have the thin gearbox bearing? I am also after a secondhand motor (gearbox not needed if you have the bearing) as i really can't afford £150 for a new one :(
Hi regarding the large thin bearing I will let you know also have you seen the motor on eBay ...cheaper than a new one
Offline aceofhearts
Hi Chas,
Against all the odds i got the motor stripped and running last night! I will post a couple of pictures of how it was (the C5 in question was found in a bog!). I managed to find some motor bearings to replace the wrecked ones. I have got some gearbox bearings from a supplier i know from work. Only thing is the outer belt drive looks quite brittle so I will have to see how it goes. I will email the guy on eBay though as it has just ended without bids.
Offline Ariablutron98
  • Time Is Money And I Own It
    • WireGamesStudios
Hi chas it's me got any spair body's that need work for a cheap price? Thanks
