Author Topic: hi chas got any scrap chassis for sale  (Read 9111 times)
Offline Ariablutron98
  • Time Is Money And I Own It
    • WireGamesStudios
« on: 16, September, 2013 - 21:09:19 »
got any scrap chassis so i can start building a c5
Re: hi chas got any scrap chassis for sale
« Reply #1 on: 17, September, 2013 - 07:46:02 »
Hi there I do have scrap one but the condition is very bad and it will need work on it ..But the problem is getting it to you ...Bye Chas
    • WireGamesStudios
« Reply #2 on: 17, September, 2013 - 17:41:40 »
trust me it does not matter
do you live neer stoke on trent
« Reply #3 on: 17, September, 2013 - 20:57:57 »
Hi there Ok ..I have just striped down a C5 that must have been outside for years all the chassis has rotted ..Any way I do have a few spares that you can have but they will need loads or elbow grease .
Here is the list ..
Chassis + 4 bolts and washers
Handle bar
Handlebar stem + the steering bracket that holds the bearings and the steering rod + the long bolt and round nut + bearings
Grips x 2
Front forks + bearings
Front brake
Front and back brake levers (You will need the little brackets and bolts that fit and hold the levers in place)
Rear axle with brake
Rear bar that goes around the body with the top hats inside
The pedals + the crank + the nuts bolts bearings
Also a light switch
A rear light (damaged) + screws
Poseable front wheel
And I may have a damaged C5 body but will have to check it out
And a few nuts  bolts and washers
But You must bear in mind that all the items will have rust /dirt / oil on them and it will take some hard work to clean them .....
But It will not be possible post the items ..
They will not cost you anything except the cost of picking them up ..I live Ilkeston ...
Offline danny7147
  • Battery level: 10
    • Bikes To The Future
« Reply #4 on: 17, September, 2013 - 21:11:14 »
You've got top hat's??? I'm desperate for a pair lol  ::) Also in need of a power switch, any of them?
« Reply #5 on: 18, September, 2013 - 07:12:10 »
there's a power switch on eBay, if this is what you mean
http://www.ebay.co.uk/itm/SINCLAIR-C5-IGNITION-BLOCK-MASTER-WITH-KEY-/281168461857?pt=UK_Collectables_OtherTransportation_RL&hash=item4176f24021
« Reply #6 on: 18, September, 2013 - 08:29:29 »
What are top hats?
Offline danny7147
  • Battery level: 10
« Reply #7 on: 18, September, 2013 - 09:06:56 »
Top hats are the little plastic bits that fit into the top of the holes in the seat to stop a hi vis mast falling through. The switch I'm after, better explained, is the one you press for the motor... I actually need it for a horn, but same switch :-)
    • WireGamesStudios
« Reply #8 on: 18, September, 2013 - 22:08:05 »
thanks alot ;D
can you keep them for me untill i find a way to get them. my stepdad is a truck driver so it should be quite easy. anyways thanks alot andi will try my hardest to get the bits taken from your hands
jadodide ;D
    • WireGamesStudios
« Reply #9 on: 18, September, 2013 - 22:10:00 »
one more thing. whats your post code so i can find out just about where you live. thank you ;D
jadodide
« Reply #10 on: 19, September, 2013 - 09:19:25 »
Hi there Jadodide I will keep the items for as long as you  like ..My postcode is Bye Chas
« Last Edit: 19, September, 2013 - 20:36:39 by C5 ENTHUSIAST + RESTORER »
    • WireGamesStudios
« Reply #11 on: 19, September, 2013 - 16:13:37 »
what is your number. are you available on sunday?
« Reply #12 on: 19, September, 2013 - 19:45:44 »
Hi there I am in Sunday .Email sent ..Chas
    • WireGamesStudios
« Reply #13 on: 19, September, 2013 - 19:56:41 »
didnot get the email could you just post your number. thank you
« Reply #14 on: 19, September, 2013 - 20:04:37 »
Hi it's
« Last Edit: 19, September, 2013 - 20:37:04 by C5 ENTHUSIAST + RESTORER »
