Author Topic: My First C5  (Read 8732 times)
Re: My First C5
« Reply #15 on: 17, December, 2009 - 23:02:16 »
i'm sure i've seen a mod for the brown fingers version by C5Martin  ???
regs
alan
ironside82
Re: My First C5
« Reply #16 on: 11, March, 2010 - 21:06:20 »
Bit of an update:
http://www.jamesblackburn.co.uk/C5/ <-- the march folder
Been quite a while getting to this stage. Still have to get a few bits from Mr Harper.
Serious amount of WD40 on the chain and its running like new.. (well nearly)
Hopefully I'll be up and running by the summer... I also need tyres & inner tubes
James
Re: My First C5
« Reply #17 on: 12, March, 2010 - 05:44:38 »
Coming along well - thanks for the photos it's alway's good to see people's restoration.
ironside82
Re: My First C5
« Reply #18 on: 13, March, 2010 - 16:30:07 »
cheers, Its quite tricky as i'm doing all the work in the loft. I live in a first floor flat which isn't ideal for C5 storage.. But you don't think of that when you've got the bug do you.
Having re assembled the front brake mechnism i'm having problems with it. When I tighten the nuts up they are either too tight stopping the brakes from pinching together or too loose and the whole thing wobbles about all over place.. have I done something wrong?
Also what are the stock levels like for the follwing parts on the c5alive shop:?
- wide 18 drive belt
- full set of tubes and tyres
- brake cable set
- anti chain bounce off
- decal set
Also what the best way to contact Adam harper for the cream fingers?
James
Re: My First C5
« Reply #19 on: 14, March, 2010 - 14:56:54 »
The front locking nut might need a bit of tweaking ?
- wide 18 drive belt no problem
- full set of tubes and tyres only a couple of sets of rears at the moment,new stock on order
- brake cable set no problem
- anti chain bounce off no problem
- decal set no problem
via text or phone call : 07889 646009
James
Adams site seems to be down at the moment, so I've included his number above  :)
Re: My First C5
« Reply #20 on: 14, March, 2010 - 17:55:48 »
Check this link for the latest update regarding Adams site;
http://c5alive.co.uk/forum/index.php?topic=1008.msg7982;topicseen#msg7982
