Author Topic: Wanted Dead or Alive: Control Box Case or Defunct Unit  (Read 2356 times)
« on: 06, October, 2012 - 20:05:05 »
some bright idiot badly chomped up the CB case, then afterwards tried to weld it shut using a soldering iron.  >:(
So I need a replacement case to keep the goodies safe and dry. A duff unit would also be just as good, and if the worst comes to the worst I'd consider a functional unit if the price is acceptable.
Please let me know of your asking price plus P&P to Germany.
Regards.
KarlG.
Re: Wanted Dead or Alive: Control Box Case or Defunct Unit
« Reply #1 on: 06, October, 2012 - 21:55:35 »
Hi there the Control box box comes in 3 sections do you have to have all 3 if not I can help ..Let me know Chas
« Reply #2 on: 07, October, 2012 - 01:43:46 »
Hi Chas,
many thanks for your offer.
Back plate could be used, has damage from bodged heat welding and an over long screw, cover/access plate can be reused, but main case is beyond repair.
Regards, KarlG.
« Reply #3 on: 07, October, 2012 - 09:12:02 »
Hi there no problem I can send you all except the cover/access plate ..Just email me your name + address
« Reply #4 on: 07, October, 2012 - 12:22:08 »
Many thanks Chas, email will be on it's way.
Cheers. KarlG.
« Reply #5 on: 07, October, 2012 - 18:29:32 »
Hi there Karl email received replied but forgot to say that the control box parts would only cost you postage ...
« Reply #6 on: 07, October, 2012 - 19:59:15 »
Hi Chas,
These are the posts that I love to read.   8)  Tell me, were you using your Santa costume when you wrote this post?  ;D
Many thanks for the help, just hope I can repay someday.
Will make up a list ASAP, just need a little time to scratch the grey matter.
Best regards. KarlG.
« Last Edit: 07, October, 2012 - 20:01:43 by KarlG »
« Reply #7 on: 07, October, 2012 - 20:21:21 »
Ok no problem ....bye Chas
« Reply #8 on: 07, October, 2012 - 23:24:26 »
Hi Chas,
list is on it's way.
Cheers. KarlG.
