Author Topic: Battery footwell clamps wanted & cone nuts for rear bearings  (Read 2855 times)
Offline POZE
Hi all
Got my grey boot C5, its missing the clamps which secure the inner side of the battery, think its 2 screws holding them in place - both sides missing. I want the C5 just right, so if anyone has these bits then let me know.
Also the cone type nuts which secure the rear wheels on, where the bearings run on. Sorry for the bad description, havent got the parts list with me today.
Cheers, Paul
Re: Battery footwell clamps wanted & cone nuts for rear bearings
« Reply #1 on: 04, May, 2011 - 10:56:13 »
Something like this ? ;
..a very rare unused battery strap kit  8)
The cone bearing nut is included in the top of the picture as well.
Offline POZE
« Reply #2 on: 05, May, 2011 - 07:45:07 »
Hey Karl
Let me check later tonight.
I managed to secure a cone bearing, not sure on condition but it should arrive in the next few days, but im still after the clamp/metal part, but if i need it i will likely take it all .
I'll come back in the next few days once the bits i brought arrive!
Cheers,
ScubaChris
« Reply #3 on: 05, May, 2011 - 12:24:49 »
My battery strap was in a very poor state when I got the C5 but it was easy enough to make a replacement as 1" webbing and plastic buckles are readily available to buy.
C.
« Reply #4 on: 05, May, 2011 - 12:29:43 »
Yep, I can supply them from stock and post them out against a creditcard order 0113 2795079
« Reply #5 on: 05, May, 2011 - 22:04:24 »
I'm a bit of a cheapskate and sometimes use a bungy strap...or sometimes just move the small black "bracket" from the back to the front of the battery to stop the battery from sliding forwards  :o :o
« Reply #6 on: 05, May, 2011 - 22:26:07 »
I use a luggage strap. 2 for £1 from poundstretcher
« Reply #7 on: 06, May, 2011 - 08:42:54 »
Good to see "improvise, adapt & overcome" is alive and well  :D
