Author Topic: run c5 with no pod or control box  (Read 5804 times)
luktobfin
« on: 03, June, 2010 - 19:30:05 »
hi i have bought a c5 and it wont run,the control box had smoke coming out of it when i checked, does any one have a wiring diagram i can use to bypass the box and pod,there was one in an earlier posting ,but the diagram is gone,many thanks,new c5 owner,lawrence.
Re: run c5 with no pod or control box
« Reply #1 on: 03, June, 2010 - 22:14:39 »
This was mentioned on an earlier topic;
http://c5alive.co.uk/forum/index.php?topic=736.0
...if we give Umpa a nudge I'm sure he will put the piccie back on  8)
« Reply #2 on: 04, June, 2010 - 06:53:31 »
your wish is my command :)
They keep cropping up !!!! - if anyone finds any more drop me an email and i'll fix'em
luktobfin
« Reply #3 on: 04, June, 2010 - 19:14:10 »
hi,thanks ever so much,i will try it over the weekend,kids are going mad to have a go,thanks again.
« Reply #4 on: 09, June, 2010 - 09:54:47 »
I did the same thing yesterday, :)
Although you lose the various original Sinclair safety features , you do end up with an easy to use and reliable c5. The downside is no thermal protection for the motor so, it will run until destruction...which I actually quite like  ;D , plus you run the risk of over discharging the battery - which is why I'll be fitting a battery monitor.
On the plus side, no more worrying about pods and control box failures - and you can push it backwards without fear of popping a fuse  ;)
« Last Edit: 09, June, 2010 - 09:58:31 by BooBoo »
« Reply #5 on: 09, June, 2010 - 15:31:37 »
Looking good Karl - a good option.
Offline alan1310
  • i wish i was that man
« Reply #6 on: 13, June, 2010 - 22:21:53 »
i run mine without pod&box and its 20 times more reliable
Offline DeanMitchell.net
« Reply #7 on: 18, July, 2013 - 16:48:45 »
Likely need to rewire mine from scratch... Have a control box but no pod so likely I will have to do the relay option.
But does anyone have a link to what relay, micro switch, fuse, etc i need to buy?
Also a schematic of the alternative wiring please?
Additionally does a leisure battery work better than a car battery?
Cheerz
Offline danny7147
  • Battery level: 10
    • Bikes To The Future
« Reply #8 on: 18, July, 2013 - 18:33:40 »
I can't help with the electrics, but I've got a 100ah van battery that's seriously heavy but gives a range of about 40 miles, and an old pair of 36ah mobility scooter batteries that do about twenty each.
Offline rekooh99
« Reply #9 on: 18, July, 2013 - 18:41:15 »
Dean just buy the safety wiring kit from chas and connect direct to the motor like I ve done it works great
« Reply #10 on: 19, July, 2013 - 16:30:26 »
Are you running it without a control box?
As I've never seen an assembled or working C5 I don't even know what's used as an accelerator
« Reply #11 on: 19, July, 2013 - 17:06:33 »
Hi there the C5 has only an on / off switch ..to control it .
Offline rekooh99
« Reply #12 on: 19, July, 2013 - 19:48:22 »
No control box  (not needed)switch on handlebars to start motor working seperate light switch and a voltagw meter from china
« Reply #13 on: 20, July, 2013 - 07:43:53 »
I just have 2 switches on my handlebars under the rubber of the grips, which I assumed were indicator switches
« Reply #14 on: 20, July, 2013 - 09:09:20 »
Hi there the two switches under the handle bar rubber are for Left side for the motor on/off .The right side for the horn .That is if they have not been changed from the original set up ..
