Author Topic: Side Screens And Hi-Vis Mast In Ebay.de  (Read 10887 times)
Re: Side Screens And Hi-Vis Mast In Ebay.de
« Reply #15 on: 09, December, 2012 - 21:30:07 »
Best of luck, you'll need them in this weather.  ;D
« Reply #16 on: 10, December, 2012 - 16:36:23 »
Just one more thing, how do you connect black clip thing on the top of the side panel onto the pod  :-\ :-\ :-\ :-\ :-\ :-\
« Reply #17 on: 10, December, 2012 - 16:43:40 »
There is a slot in the pod that you slide them into.
« Reply #18 on: 10, December, 2012 - 18:44:48 »
That is what I have done but do you need anything to hold it in with like a screw  :-\ :-\ :-\
« Reply #19 on: 10, December, 2012 - 19:52:19 »
Hi there Luke just push the clip through and open it out and it will hold in place ...
« Reply #20 on: 10, December, 2012 - 20:32:03 »
Yep it holds  ;D ;D ;D ;D ;D ;) ;) ;)
« Reply #21 on: 11, December, 2012 - 17:13:31 »
« Reply #22 on: 11, December, 2012 - 17:15:50 »
The panel is to tight and the velcrow wont reach
file:///D:/DCIM/100NIKON/DSCN0225.JPG
« Reply #23 on: 11, December, 2012 - 19:10:30 »
Hi Luke,
your links don't function. You should check your post, before posting, by using the 'Preview' function, here you can test your link(s) to ensure it/they is/are working correctly.
Why don't you use Photobucket as was recomended?
« Reply #24 on: 11, December, 2012 - 20:40:15 »
I think you need a twitter or Facebook account which I don't have I'll try to con my dad to let me get one
« Reply #25 on: 11, December, 2012 - 21:11:18 »
Hi Luke,
you don't need anything other than to click on 'sign up for free', fill in the application form, slide an arrow, click on 'Sign up' then wait for an email from photobucket requesting that you click on a given link. So easy, but there may be a problem with your age. If there is just ask your Dad if he will open an account for you.
One thing to remember is that as a freebie your upload is limited to 2gb.
« Reply #26 on: 12, December, 2012 - 07:17:11 »
I have signed up, now I have got to work out how to use it now  8) 8) 8)
« Reply #27 on: 12, December, 2012 - 07:29:53 »
Also how many pics can you up load with 2GB  ??? ???
Offline dansretropod
    • www.c5owners.com
« Reply #28 on: 12, December, 2012 - 08:24:49 »
Quote
Lots.  About 500 dependant on image quality/resolution.
« Reply #29 on: 13, December, 2012 - 06:59:43 »
This is my first post with a picture
Is this where the side Panel clips go
« Last Edit: 13, December, 2012 - 07:04:32 by Luke Salsbury »
