Author Topic: J'ai un C5!!!!  (Read 50019 times)
Re: J'ai un C5!!!!
« Reply #90 on: 12, May, 2009 - 21:14:18 »
Hi Karl,
How long would it take for an order to get to me if I were to order tonight?
Mark
Hi Mark
Once payment is received I always try to get everything posted the next working day
Re: J'ai un C5!!!!
« Reply #91 on: 12, May, 2009 - 21:21:18 »
Also, how do you get the rear break light off (opened up?)
Mark
Andy is correct, once you have undone the two screws the rear light unit lifts away from the bodyshell. But the red lens and grey backing are bonded together, the only removable part is the black bulb holder - this just pulls apart from the back of the light unit.
Offline minimin
Re: J'ai un C5!!!!
« Reply #92 on: 12, May, 2009 - 22:10:02 »
Thanks Karl + Andy.
I'm going to place an order now. But are the LED bulbs compatable with the back ones?
Mark
Re: J'ai un C5!!!!
« Reply #93 on: 12, May, 2009 - 22:15:02 »
Thanks Karl + Andy.
Mark
Yes mate,the bulbs fit both front and rear lights.
Offline minimin
Re: J'ai un C5!!!!
« Reply #94 on: 13, May, 2009 - 00:14:01 »
Not to be cheeky, but does anyone have a faulty control box they no longer want?
Mark
Re: J'ai un C5!!!!
« Reply #95 on: 13, May, 2009 - 06:24:42 »
Theres one on e-bay which runs out in about 8 hours
Offline scott
Re: J'ai un C5!!!!
« Reply #96 on: 13, May, 2009 - 20:26:27 »
IVE GOT A SPARE CONTROL BOX THAT NEEDS REPAIRING ,IT IS REPAIRABLE AND C5 MARTIN HAS IT AT THE MOMENT. MAKE ME AN OFFER  UNLESS U HAVE SPARES U WANT TO SWAP,CHEERS SCOTT
Offline minimin
Re: J'ai un C5!!!!
« Reply #97 on: 13, May, 2009 - 20:58:49 »
Great! Whats wrong with it? Does it have all the wires?
And what to buy??? What shall I get? i only have the chain tensioner, so with the cog and spring, What shall I buy from the shop to get it working again?
Mark
Offline minimin
Re: J'ai un C5!!!!
« Reply #99 on: 13, May, 2009 - 23:05:53 »
Offline scott
Re: J'ai un C5!!!!
« Reply #100 on: 13, May, 2009 - 23:08:36 »
hello mark  the control box is complete i think it needs some diodes and soldering work which c5 martin can fix for £27.00  i did replace some fuses in it and some new screws and bolts as for wires it has two  all other wires are from the loom,motor and battery feed they are separate parts which i dont have, try emailing karl he might be able to help you out with them parts, as for the control box its yours if u want it  give me a call tomorrow and we can have a chat about it 07737828648 cheers scott.
Re: J'ai un C5!!!!
« Reply #101 on: 14, May, 2009 - 13:05:00 »
mark,
Sounds like you might have it all wrapped up, but just for reference - what is this shunt you talk of ?
here's a pick of my spare controller
My best guess is you mean the red relay is that correct ?
Offline minimin
Re: J'ai un C5!!!!
« Reply #102 on: 14, May, 2009 - 16:23:15 »
Close....
Its the big silver thing on the bottom left.
Mark
Re: J'ai un C5!!!!
« Reply #103 on: 14, May, 2009 - 16:30:23 »
Well if it all goes pear shaped and you can't get another, I can tell you what the components are. The heat sink should be easy to make. When you say they are obsolete, do to mean they actually sold these as a replacement part ??
Offline minimin
Re: J'ai un C5!!!!
« Reply #104 on: 14, May, 2009 - 17:04:07 »
Nope, it was the wires that had gone.  :(
