Author Topic: Steam Clean C5?  (Read 4073 times)
Offline vanpeebles
Steam Clean C5?
« on: 07, April, 2011 - 08:34:59 »
I noticed in one thread someone used a wallpaper steamer to clean a C5, would a Polti steam cleaner be ok? And is it not too hot for the plastic? Cheers! Just after cleaning tips with an ingrained C5.
Re: Steam Clean C5?
« Reply #1 on: 07, April, 2011 - 09:07:01 »
Hi there I did use a wallpaper stripper on the C5  as you can see not a bad result ..But it was a lot of hard work ...but had to use other means of cleaning ..
« Last Edit: 07, April, 2011 - 15:10:23 by C5 ENTHUSIAST + RESTORER »
Re: Steam Clean C5?
« Reply #2 on: 07, April, 2011 - 09:53:09 »
Hi there I did use a wallpaper stripper on the C5  as you can see not a bad result ..But it was a lot of hard work ...but had to use other means of cleaing ..
Same here, I also used a wallpaper stripper to attack some stubborn marks on the c5 but also used some bathroom cleaning chemicals as well . Tesco do a nice cheap "cream cleaner" for about 45p a bottle that works quite well  :)
Offline vanpeebles
Re: Steam Clean C5?
« Reply #3 on: 07, April, 2011 - 10:51:06 »
I've been using some cream cleaner with a 3M style scotchbrite pad and it's a lot whiter but still looks very grubby in places. I might try the steam clean on the weekend and report back! Actually the steam might shift the spots of paint on it.
Offline Pyrasanth
Re: Steam Clean C5?
« Reply #4 on: 07, April, 2011 - 15:02:43 »
I was really naughty and took the body off and jetwashed it with my karcher and it came up tumps this is before i put on the electrics and stickers and I would use this method again for sure.
Cheers
Gary  ;D
Re: Steam Clean C5?
« Reply #5 on: 08, April, 2011 - 06:37:37 »
I used the pressure washer at work when restoring mine, stripped it all down first, then with various cleaning chemicals scrubbed on it then I pressure washed it, seem to do the job, altough don't do this if you want to keep any of the original stickers, as it got them off easy aswell.
