Author Topic: Rubber Grommets  (Read 2084 times)
Rubber Grommets
« on: 24, November, 2012 - 10:47:46 »
What do the rubber grommets do for the High Vis Mast. dose it effect how the Vis mast stands. My C5 dose not have the Grommets they have been lost sometime in the past. It did not have them when I bought it.  :( :(
Re: Rubber Grommets
« Reply #1 on: 24, November, 2012 - 11:36:23 »
As far as I know, they're simply a finishing touch.
Re: Rubber Grommets
« Reply #2 on: 24, November, 2012 - 11:41:34 »
The internal diameter is correct for the Hi-Vis mast poles, if they are missing the mast will not be held correctly.
