Author Topic: Drive Clicking Alternative Fix (Variation on Cable tie)  (Read 3189 times)
Offline Robosoft
    • Sinclair Research
« on: 30, July, 2011 - 20:02:16 »
Today on another c5 I had the clicking of death.
Very bad design - The fence is way to thin and should have been set back towards the gears.
Anyway two small holes later.
On the next c5 i think i will put a bolt through the fence perfectly horizontal so the fence can be adjusted.
A better solution is to get a aluminum block formed to fit under the gearbox.
« Last Edit: 30, July, 2011 - 20:24:23 by Robosoft »
Re: Drive Clicking Alternative Fix (Variation on Cable tie)
« Reply #1 on: 31, July, 2011 - 13:44:15 »
Looks like a good variation of the theme  8)
Anything that improves the original poor design has to be a good thing  :).
« Reply #2 on: 31, July, 2011 - 21:07:55 »
Another candidate for the bodge it section  ;)
« Reply #3 on: 31, July, 2011 - 21:21:57 »
Robosoft, Good idea about the ali block now for Chas to produce it ;D ;D ;D ;D ;D ;D ;D
« Reply #4 on: 01, August, 2011 - 22:43:47 »
Just got back from holiday 3 weeks away from my c5s to long ...The next project I will be working on is the chain tensioner .......
