Author Topic: Paint  (Read 8883 times)
blabblub
Paint
« on: 22, April, 2008 - 18:11:43 »
I am gonna paint one of me C5s matt black can anyone advise what paint I should use
Blabblubububububububububub!!!!
Offline fezza_rs
Re: Paint
« Reply #1 on: 22, April, 2008 - 19:31:55 »
do you have a compressor?
blabblub
Re: Paint
« Reply #2 on: 22, April, 2008 - 19:49:56 »
Nah Ive got an Audi A4 !!
Seriously I aint got a compressor
Kev
Offline fezza_rs
Re: Paint
« Reply #3 on: 22, April, 2008 - 20:12:31 »
ok ill give you an ebay list btw just incase your wonderin i was a painter lol
blabblub
Re: Paint
« Reply #4 on: 22, April, 2008 - 20:34:19 »
Cheers
That would be great
Kev
Offline fezza_rs
Re: Paint
« Reply #5 on: 22, April, 2008 - 20:44:56 »
Clean the body off with ulta warm soapy (washing up liquid) water
then scrub every part you want to paint hard with this occasionaly dipping it in the water make sure you rub everywhere!.......
http://cgi.ebay.co.uk/3M-Scotchbrite-Handpads-7447-x10-AVFN-Maroon-NEW_W0QQitemZ130215031275QQcmdZViewItem?_trksid=p3286.c81.m20.l1116
Then rinse off and allow to dry as in bone dessert dry.
Then mask the parts you dont want to paint and spray the areas you do with a coat of this.......
http://cgi.ebay.co.uk/450ml-Aerosol-Upol-Grip-4-Universal-Adhesion-Promoter_W0QQitemZ330224707012QQcmdZViewItem?_trksid=p3286.c81.m20.l1116
allow to dry bout 10mins then spray on a light coat of this.......
http://cgi.ebay.co.uk/4-x-400ml-CANS-OF-HYCOTE-PLASTIC-PRIMER-SPRAY_W0QQitemZ320242696598QQcmdZViewItem
then apply another 2 medium coats of the plastic primer and allow to dry overnight.
then apply your matte black light coat first then 2 medum coats and allow to dry.
Stand back and admire your stealth c5!
blabblub
Re: Paint
« Reply #6 on: 22, April, 2008 - 20:51:48 »
Fantastic
Am off to Ebayland now
Cheers
Kev ;D
DonkeySpank
Re: Paint
« Reply #7 on: 23, April, 2008 - 10:21:01 »
If it's gonna be a black C5 you just HAVE to put a whirly red light on the front like Knight Rider! hahaha! ;) :D
blabblub
Re: Paint
« Reply #8 on: 23, April, 2008 - 10:25:56 »
Good idea !
I have just ordered 4 12v strobe lights offa Ebay , so we will see what that does.
I am spraying it coz the body shell is a bit knackered , loads of gouges and a couple of holes underneath
Re: Paint
« Reply #9 on: 23, April, 2008 - 13:37:51 »
... and a couple of holes underneath
You might want to leave those holes , might be useful to drain away the excess "adrenalin" when your brakes fail  :P
blabblub
Re: Paint
« Reply #10 on: 23, April, 2008 - 14:09:58 »
Good thinking , I will add mesh seat on list of things to do
Offline fezza_rs
Re: Paint
« Reply #11 on: 23, April, 2008 - 21:04:58 »
if you prepair it in the way i have set out the rattle tin method will look spot on
Hank Ladd
Re: Paint
« Reply #12 on: 24, April, 2008 - 13:45:35 »
Kev
I am happy to lend you my compressor mate if you want to go that route - It will result in a better job in the long run, but as Hank has proved, spray cans can also do a better than superb job !
Mark
Cheers Mate! Yeah I did use loads more paint than I could of. But that was due to lack of funds for compressor and no where to spray inside. I was out in the wind so the wind was becoming yellow! lol But it does look ok, im going to one day do another one! :)
Hank
blabblub
Re: Paint
« Reply #13 on: 24, April, 2008 - 20:49:57 »
I know what you mean about the wind Hank , I think Ive redesigned some of the neighbours washing  :-[
Hank Ladd
Re: Paint
« Reply #14 on: 25, April, 2008 - 08:19:49 »
hahaha! I did end up- using a tarpaulin and arranged it over the c5 so it was kinda covered, you could try that to block out some of the wind!
Hank
