Author Topic: Another C5 picked up thanks to Karl  (Read 9524 times)
« on: 21, August, 2010 - 19:19:05 »
As you can see another C5 to rebuild when time allows .This one used in a panto for about 4 years till 1999.the put in storage .It was to play a part of a police car chasing robbers from the film Charlie Chaplin (Keystone cops)...Will to get some photos if possible ...As you can see there is a lot of work to do on it will keep you posted ...
« Last Edit: 21, August, 2010 - 21:45:20 by C5 ENTHUSIAST + RESTORER »
Re: Another C5 picked up thanks to Karl
« Reply #1 on: 21, August, 2010 - 21:59:46 »
More photos
« Reply #2 on: 21, August, 2010 - 22:15:23 »
Blimey Chas - you've got your work cut out with that one - is it covered in some kind of tape ? Keep the photo's coming be great to see you get it back to it's proper condition. :)
« Reply #3 on: 21, August, 2010 - 22:35:42 »
Nice to see it being restored and not scrapped  :o
Looks fairly complete ,even if the motor has been chopped out !
Like Marty says it needs a bit of work  :)
« Reply #4 on: 22, August, 2010 - 21:36:12 »
Thats a bit more of a challenge for you Chas, keep us posted with the pictures.
« Reply #5 on: 23, August, 2010 - 08:22:46 »
Yes it will be a challenge the worst thing is the tape ...I v taken it off but it's left a sticky residue and it's going to be hard to get it back as it should be.But at the moment I'm testing /repairing pods ,Then must complete the restoration of the C5 .when that is finished I will be building another petrol/Sinclair c5 motor C5 like the last one I built some time ago ....
will keep photos posted
« Reply #6 on: 23, August, 2010 - 13:24:47 »
Sounds like some serious modding is about to take place....looking forward to that  ;)
Offline jk
« Reply #7 on: 24, August, 2010 - 14:22:52 »
Try using a water displacing/lubricating aerosol to remove the sticky residue. It works great on that sort of stuff. I use WD40.
jason
« Reply #8 on: 24, August, 2010 - 14:56:10 »
Ok thanks Jason will try it right now and let you know if it works .bye Chas
« Reply #9 on: 25, August, 2010 - 06:22:36 »
Tar and glue remover is really good and and good hot pressure wash will do the trick
« Reply #10 on: 25, August, 2010 - 08:32:20 »
Thanks Andy will try it . Chas
« Reply #11 on: 02, September, 2010 - 08:07:05 »
Just started to restor the above (Panto) this one will be a hybrid  a petrol and an electric one ...Same as the one I made some while ago and the one that I will be using at Brooklands .
photos to follow ,
« Reply #12 on: 30, September, 2010 - 18:26:08 »
More photos of the C5 called panto ,as it was used in a Panto for a few years ...
was not able to use it for the petrol/electric due to condition of the body ..take a look
But as you can see we are getting there
« Reply #13 on: 30, September, 2010 - 19:23:47 »
Looking a lot better already Chas  :)
« Reply #14 on: 01, October, 2010 - 13:14:25 »
Just some more photo's of the Panto C5
As you will see it's just about finished (But I will give it a once over after I have restored it )
But as you can see the boot has yet to be cleaned ....
