Author Topic: MAKERS OF THE ORIGINAL SWITCH  (Read 2502 times)
« Last Edit: 03, August, 2013 - 12:30:29 by PLOD11 »
Offline danny7147
  • Battery level: 10
    • Bikes To The Future
Re: MAKERS OF THE ORIGINAL SWITCH
« Reply #1 on: 03, August, 2013 - 15:27:43 »
Interesting find! Have you found out anything regarding prices etc? I'm still after one for my horn.
Offline Howard81
« Reply #2 on: 03, August, 2013 - 17:48:38 »
There are lots of switches that can fit. It is the metal bracket it affixes to that is the hard bit to source!
Offline gertk
  • When in doubt: C5
« Reply #3 on: 03, August, 2013 - 18:47:06 »
You could try and make a simple U shape bracket out of thin sheet metal and clamp it in between the standard bracket and the handlebar.
If you give it an H shape with a thicker horizontal bar wide enough to go underneath the clamp, then bend up the sides and drill small holes for the switch. (metric 2mm / M2 will fit nicely)
« Reply #4 on: 04, August, 2013 - 11:28:51 »
Maybe a project for Chas  ;)
