Author Topic: Retro Andy's project  (Read 11123 times)
Re: Retro Andy's project
« Reply #15 on: 15, April, 2009 - 13:39:40 »
Charlie's back on the road again, i removed the tensioner, give it a good clean and lubricate, and fitted a better chain (the clip was'nt broken) and it seems much better.
« Last Edit: 20, December, 2012 - 22:39:56 by Retro Andy »
Re: Reto Andy's project
« Reply #16 on: 15, April, 2009 - 16:20:53 »
Which chain did you fit andy ?  Mines crap and would like to replace it. Do you have some kind of a link ?
Cheers
Ian
« Reply #17 on: 16, April, 2009 - 10:03:11 »
I got it from a different bike shop in town to the previous one, the brand is KMC silent bike chain, i had a quick try after fitting it and pedaled as fast as i could with no problems, still need to try it a bit further and up a hill to be sure, but it sounds much better than before.
« Reply #18 on: 17, May, 2009 - 08:59:01 »
Found these pictures the other day, i took them last year before the royal run when i was trying the route out, he know has the C5 Alive black mudflaps, a high vis mast, a pair of mirrors and i did remove the plate.
« Last Edit: 17, May, 2009 - 09:00:36 by Retro Andy »
c515mph
« Reply #19 on: 06, April, 2011 - 21:26:04 »
I recently  had the same problem and it turned out to be the spring on the chain tensioner.
Replaced spring and now all ok.
