Author Topic: New restoration for friends of Simon  (Read 13585 times)
« on: 08, April, 2013 - 21:58:36 »
Hi just started my next restoration for some friends of Simon ..Here are some of the parts after being stripped off .Some of the parts will be used others will be scraped ..
« Last Edit: 08, April, 2013 - 22:03:45 by C5 ENTHUSIAST + RESTORER »
Re: New restoration for friends of Simon
« Reply #1 on: 09, April, 2013 - 08:10:12 »
Here is the body that I will be using .
« Last Edit: 09, April, 2013 - 08:18:47 by C5 ENTHUSIAST + RESTORER »
« Reply #2 on: 09, April, 2013 - 08:16:40 »
Here are some of the parts that I will be fitting
« Reply #3 on: 09, April, 2013 - 10:19:07 »
Brilliant Chas.
Looking forward to seeing all the progress.
« Reply #4 on: 09, April, 2013 - 20:24:06 »
Been working on the chassis..before and after
« Last Edit: 09, April, 2013 - 20:28:58 by C5 ENTHUSIAST + RESTORER »
« Reply #5 on: 09, April, 2013 - 20:43:23 »
Looks awesome Chas.
« Reply #6 on: 09, April, 2013 - 20:45:48 »
Yes it looks great 5 coats of paint ..
« Reply #7 on: 10, April, 2013 - 18:11:46 »
Just cleaned and sprayed some items ....
Just started the build up
« Last Edit: 10, April, 2013 - 18:17:44 by C5 ENTHUSIAST + RESTORER »
« Reply #8 on: 11, April, 2013 - 08:53:18 »
Just a couple more items cleaned ready for fitting
BEFORE /AFTER
« Last Edit: 11, April, 2013 - 09:40:53 by C5 ENTHUSIAST + RESTORER »
« Reply #9 on: 11, April, 2013 - 15:53:39 »
A few more items fitted ..Coming on nicely .
The next thing is to check out a harness before fitting in the body channel
« Last Edit: 11, April, 2013 - 15:59:08 by C5 ENTHUSIAST + RESTORER »
« Reply #10 on: 11, April, 2013 - 16:04:16 »
Looks perfect Chas.  Loving the pictures and seeing the progress.
« Reply #11 on: 11, April, 2013 - 16:11:38 »
Thanks ......
« Reply #12 on: 11, April, 2013 - 21:22:31 »
Just checking the wiring / control box / and the Pod and as you can see they seem to be ok .But before I can be sure they will have to be tested when the C5 is completed and on a test run ...
« Reply #13 on: 13, April, 2013 - 20:06:27 »
Ok I have just put the chassis on and fitted the wiring inside the channel then fitted the handle bar + the brake leavers .Peddles and chain connected .
Fitted a new battery strap and cleaned all the underneath ..,Start and horn push buttons fitted to the handle bars .Front light fitted
The next thing is to check out the wiring before conecting things up just to see if it still works ok ..
« Last Edit: 13, April, 2013 - 20:20:33 by C5 ENTHUSIAST + RESTORER »
« Reply #14 on: 14, April, 2013 - 17:55:52 »
As you can see just checking the wiring after putting it in place ..And it seems ok
Ok the electronics seem to be ok .So I started work on the motor ..
As you can see The small bearings are still on the shaft .(Sometimes the shaft breaks of due the the motor dropping of the support and putting a lot of strain on the shaft ..)
Teeth in the gearbox are in great condition
« Last Edit: 14, April, 2013 - 21:07:25 by C5 ENTHUSIAST + RESTORER »
