Author Topic: what a day !  (Read 4276 times)
what a day !
« on: 07, July, 2009 - 22:31:05 »
well I fit a cycle computer and set off to work, I check the calibration with a satnav and its spot on.
Then it chucks it down with rain, so much that the pod starts beeping - even tho the battery is fine, then it starts to go even when I dont press the go button.
I get to work, and the lighting has knocked the powe out, so i was on time even tho I was late - lol
I take the pod off to check for water ingress, only to find its fine, I check the control box and cant see anything wet, so I put it back together and find the pod wont light up.  Turns out in my haste I pulled wire 1 from the pod connector.
I set off home at 10pm only to find my front light has blown - but even tho the pod did not light up the c5 worked perfectly.
There is a god - lol
Re: what a day !
« Reply #1 on: 07, July, 2009 - 22:51:59 »
Glad you made it back home okay mate, will you be able to fix the pod wire  ?
Re: what a day !
« Reply #2 on: 08, July, 2009 - 08:31:25 »
There's no stopping your C5 !!!! - glad you got home safely. :D :D
Re: what a day !
« Reply #3 on: 08, July, 2009 - 10:42:23 »
Thanx guys, yes I think I can fix it.  It will have to wait tho as I have pulled my back out - lol
I'm on the TENS machine - but will recover.
Re: what a day !
« Reply #4 on: 08, July, 2009 - 18:39:36 »
ouch...know how you feel mate. Dodgy back is no fun at all  :-\
