Author Topic: Droppping the chassis  (Read 2697 times)
« on: 24, January, 2012 - 15:53:09 »
Hi guys,
I am looking at dropping the chassis (without the black hoop) to de rust it and re-spray it. Am I right in thinking that if I remove; the pedals, bottom bracket, 4 body-chassis screws, four nuts securing the rear 'hoop' to the chassis, control box, motor & snip the various cable ties holding the wiring (to keep the wiring with the body) the chassis should come out the bottom? I have a bicycle lift/ramp type thing which I could use to lift the body off with the wiring.
Re: Droppping the chassis
« Reply #1 on: 24, January, 2012 - 16:19:47 »
Hi don't forget the steering stem /handle bars /brake cables .Also under the back light there 2 screws to undo if you want to take of the back hoop you will find it easier to lift the body off without it ..
good luck ...Chas
« Last Edit: 24, January, 2012 - 16:42:16 by C5 ENTHUSIAST + RESTORER »
« Reply #2 on: 24, January, 2012 - 19:39:54 »
They are quite easy when you get going, I am on my 3rd refurb. If you can do the re-build of a jag engine you will have no problems. ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Have fun...................Lance
