Author Topic: Flashing lights  (Read 7021 times)
Flashing lights
« on: 16, February, 2009 - 10:34:28 »
Although the c5 has two large reflectors built into the rear light assembly, for peace of mind I still like to make sure I can be seen by other road users.
To help make the c5 more visible I've been adding various types of flashing lights, some have proved to be better than others.
The cheapest was from one of the "pound shops" ;
Although this was really cheap, it wasn't that good. The batteries kept falling out causing the light to stop working. Even when it was working, the light wasn't very bright.
The lens broke when opening the casing to replace the batteries, and now the bracket that holds the light has also snapped. :(
Even though it costs so little, it cannot be recommended
« Last Edit: 16, February, 2009 - 10:36:11 by Karl (C5Alive) »
Re: Flashing lights
« Reply #1 on: 16, February, 2009 - 10:41:06 »
This is the light fitted, upside down, to the bottom of the boot on "Moneypit"
It was purchased 2 years ago from Argos as part of a cycling set, and has been excellent.
The casing was damaged when the boot fell off (should use boot clips !), but despite this the light still works. Nice and bright, and with various display "modes", the batteries seem to last for ever due to the low energy consumption of the LED's.
Quite happy with this one  :)
Re: Flashing lights
« Reply #2 on: 16, February, 2009 - 10:47:41 »
This is another excellent light ;
It costs less than £10 from Halfords and is a good strong design. The LED's are nice and bright and the batteries last well. The only downside is that it doesn't have various "modes" - just fixed light, or flashing  :(. The light from Argos has various display modes, which I like  :)
I've fixed it to the specially made bracket that supports the hi-vis flag fitted to "moneypit".
Works well and good value. Recommended. ;)
« Last Edit: 16, February, 2009 - 10:49:50 by Karl (C5Alive) »
Offline Kurt
Re: Flashing lights
« Reply #3 on: 21, February, 2009 - 16:26:14 »
This is my 'Blue Peter' home made special based on the original High Mast design with a TL-LD610-R Cat Eye on top.
The Cat Eye has various modes, from constant, flashing, 'Cyclon/Knight Rider' back and forth mode and runs on two AAA batteries. It is very visible, bright and has 30 hour (constant) - 60 hour (flashing) run time. Costs about £18 from most bike shops.
Had it's first real test run when we had some nasty weather at the Horsham Pub run meet, and reports from those behind me was that it made me very visible even from some considerable distance away.
Mk II model will have a couple of reflective material bars going across and happy to negotiate with Karl advertising space on one for a free C5alive sticker!
Offline Kurt
Re: Flashing lights
« Reply #4 on: 21, February, 2009 - 16:28:33 »
Re: Flashing lights
« Reply #5 on: 21, February, 2009 - 18:04:41 »
looks like you've been busy with the cleaning products mate , your c5 is looking fab  8)
The light you've got there is superb , it was really effective on that Horsham run  ;)
Re: Flashing lights
« Reply #6 on: 22, February, 2009 - 07:53:33 »
Has anyone ever thought of brake lights ?
Offline fezza_rs
Re: Flashing lights
« Reply #7 on: 22, February, 2009 - 08:43:25 »
yeh dead easy to do just look on any of the scooter sites such as tmc scooters they do brake levers with the brake light switch contacts on them.
