Author Topic: C5 RED/WHITE/BLACK  (Read 3360 times)
C5 RED/WHITE/BLACK
« on: 28, January, 2012 - 14:24:34 »
Hi just moved the C5s into the garage so decided to take a few photo's but forgot to put the back wheel covers on the white c5 ...But as you can see they look OK (The Red one is going to be collected some time next week it's of to Ireland ...)
« Last Edit: 28, January, 2012 - 14:27:11 by C5 ENTHUSIAST + RESTORER »
Re: C5 RED/WHITE/BLACK
« Reply #1 on: 28, January, 2012 - 16:26:36 »
Nice one.
I forgot to ask what the led readouts pare for on the bat mobile?
« Reply #2 on: 28, January, 2012 - 18:20:16 »
Nice trio Chas, How many have you got now...................
BigglesBear
« Reply #3 on: 28, January, 2012 - 18:35:01 »
Very nice pics of your  C5's must admit look better with mirrors Fitted ... 8) 8) 8)
« Reply #4 on: 29, January, 2012 - 10:04:25 »
Regarding the Red Readouts ....On the pod I have a blue 24 volt meter + a red 100 amp meter .Also I changed the Pod led layout  far left and right are green power indicators one each end then there are 12 high bright red leds (6 each side) that when the indicators are on the leds light up at the same time .Also when  you put on the hazards they all flash at once ...Just below the pod I have fitted a temp gauge connected to the speed controller ..Also the left power switch now is a headlight flasher ....Also fitted a back brake light .And also fitted some blue neon lights each side the foot wells ..   Regarding how many C5s I have To many  about 15 ..
« Last Edit: 29, January, 2012 - 10:32:15 by C5 ENTHUSIAST + RESTORER »
« Reply #5 on: 29, January, 2012 - 11:15:15 »
Pimped to the max!
« Reply #6 on: 29, January, 2012 - 16:09:09 »
Top photo Chas - most impressed  :)
« Reply #7 on: 29, January, 2012 - 16:20:04 »
Thanks for the comments ......bye Chas
 (still need to give it a good run to test it out )
