Author Topic: Restoration for a member ....  (Read 16025 times)
Re: Restoration for a member ....
« Reply #15 on: 23, March, 2015 - 19:23:33 »
Hi Ray the hammer was a red herring
« Reply #16 on: 23, March, 2015 - 19:27:49 »
Well done Karl both where put on wrong but if you don't know it's easy done
Did you find the small items .i was not sure what they where as they where that small will they work as you want them to if you can find them
« Reply #17 on: 23, March, 2015 - 21:25:15 »
Hi Chas,
those minute things, that is if they are realy there, are thermistors.
In the past. on many occasions, I've had to check soldering under the microscope, but this will be the first time ever that I have to solder under a microscope.  :o :o But before I do anything I have to cook them.  ;);D
Cheers.
Karl.
P.S. did you not receive my last email, as I've received no reply?
« Reply #18 on: 23, March, 2015 - 21:30:10 »
Hi Karl yes I did but sorry that I have not replied to you .will do in the Morning
All the best Chas ps good look with the soldering....and let me know how you get on
« Reply #19 on: 24, March, 2015 - 12:04:10 »
Hi Chas,
it'll be some time before I get round to the thermistors, I'll be busy modding all my CBs for more reliability, uprated power supply transistor, heatsinks, etc.
« Reply #20 on: 24, March, 2015 - 18:35:58 »
Did a little more on the chassis ....Can anyone spot the mistake ??????????
« Last Edit: 24, March, 2015 - 18:40:59 by C5 ENTHUSIAST + RESTORER »
« Reply #21 on: 25, March, 2015 - 12:19:41 »
Hi Chas,
could it be the back brake cable mounting bracket is missing?
« Reply #22 on: 25, March, 2015 - 22:23:38 »
No ?????.
Had a go at cleaning the body today
« Reply #23 on: 26, March, 2015 - 19:00:04 »
Body cleaned but will need a lot more time spending on it .
So did a little on the chassis
« Last Edit: 26, March, 2015 - 19:09:32 by C5 ENTHUSIAST + RESTORER »
« Reply #24 on: 29, March, 2015 - 18:42:33 »
0
« Last Edit: 29, March, 2015 - 18:47:17 by C5 ENTHUSIAST + RESTORER »
« Reply #25 on: 29, March, 2015 - 18:44:21 »
Stripped the motor down today and I was surprised with the condition as it was in good nick but as it was hardly used and had only one owner from new
« Last Edit: 29, March, 2015 - 18:46:01 by C5 ENTHUSIAST + RESTORER »
« Reply #26 on: 29, March, 2015 - 18:47:56 »
More of the same
Cleaned greased put together and tested working great
« Last Edit: 29, March, 2015 - 18:54:29 by C5 ENTHUSIAST + RESTORER »
« Reply #27 on: 29, March, 2015 - 20:48:00 »
Hi Chas,
nifty tool you have there, must save a lot of fiddling and cursing.  :D :D
Pitty for the four or five motors that I have to service and mod, it would be too much work to reproduce one. :(
Never mind.
Av phun.
Karl.
« Reply #28 on: 29, March, 2015 - 21:34:40 »
Hi Karl I can send you one to use if you like just let me know Chas
« Reply #29 on: 29, March, 2015 - 23:15:06 »
Hi Chas,
many thanks for the offer, but if I accepted it would be gone for a long time.
Due to lack of space I can only work on one C5 at a time, and it's taking me one hell of a lot of time searching for and buying materials etc. For example, remember how long ago it was when we spoke about the pedal crank wheel, well it's taken me up till last week to come up with one that I might be able to use.  It's not the first one I've found, just the most suitable.
Once more, many thanks for, yet again, being helpful.
Best regards.
Karl.
