Author Topic: Brake Cable  (Read 3194 times)
Offline USA-C5-Owner
Brake Cable
« on: 10, June, 2015 - 14:26:52 »
My rear brake cable snapped from the handle.  Is this repairable or do I need another cable?  Is this cable universal or is there a special cable I need tp purchase to use on the C5?  Thanks for any help on this.
Offline dadandjames
Re: Brake Cable
« Reply #1 on: 10, June, 2015 - 17:52:03 »
Same happened to me and I used a standard bicycle one.
Martin
Re: Brake Cable
« Reply #2 on: 10, June, 2015 - 21:42:45 »
ok, Ill stop by the store and see what they have in stock to use.  Thanks Martin!
Re: Brake Cable
« Reply #3 on: 13, July, 2015 - 15:57:19 »
Update:
I replaced both cables.  The front brake cable went very well.  I spaced the brake pads 1/8" away from the front tire and now the front brake works very well and grabs tight.
The problem is on the back cable.  After cable installation, when I pull the hand brake, the cable pulls the rear lever, but the movement is not enough to make the rear braking usable.  The "offset" lobe in the drum brake dosn't turn enough to make contact.  I can turn the lever with my hand and all works well, but using the hand-brake on the handlebar does little.   Where am I going wrong on this?
Adam
Re: Brake Cable
« Reply #4 on: 13, July, 2015 - 17:01:13 »
Hi Adam,
I had the same problem with my road bike. With no pressure on the hand brake lever, pull the brake cable until tensioned, then apply pressure to the brake lever (wheel end) until the brake starts to bind, back-off a little, then tighten the clamp.
This should do it.
Av phun.
KarlG.
Re: Brake Cable
« Reply #5 on: 13, July, 2015 - 18:36:22 »
I'll give this a try, thanks Karl.
