Author Topic: Crank (Bottom bracket) Removal  (Read 13581 times)
c5martin
« on: 21, September, 2008 - 21:43:50 »
Remove pedal caps
Remove Front Sprocket Covers
Fit pedal crank removal tool (can be purchased at any bicycle shop)
Remove pedals
Spin/Knock off locking ring on Near side crank
Fit crank removal star to crank bolt
NOTE: NearSide (left hand when sat on the c5) is std screw thread (Clock wise tighten : Anti-clockwise Loosen)
OffSide is reverse thread.
Spin off
Slide out crank (sometimes called bottom bracket) with ball races.
Refitting is the reverse of removing - however ensure the ball races are thoughly cleaned and well greased along with the bearing cups.
Re: Crank (Bottom bracket) Removal
« Reply #1 on: 14, August, 2009 - 08:43:15 »
I took these piccies whilst repairing "Dave", thought they might help visualise what c5martin is saying;
The hammer and screwdriver might not be the proper tools, but used carefully they do the job  :)
There is a silver locking ring on the other side that can also be undone using the same method..
« Reply #2 on: 14, August, 2009 - 12:28:43 »
I wish these pictures were on here when I was dismantling my C5, as it was years since I had removed such a thing of a bike and was'nt 100% sure what I was doing at the time.
Nitrowing
« Reply #3 on: 20, August, 2009 - 21:32:48 »
Has anyone got the bottom bracket size? I'd like to replace mine with a sealed unit want to strip it apart and then sit around with it unusable.
« Reply #4 on: 21, August, 2009 - 10:33:37 »
eh?
Nitrowing
« Reply #5 on: 21, August, 2009 - 22:13:51 »
eh?
Bottom brackets are made as sealed units these days - you fit and forget! I have a titanium lying around from when I owned a bicycle shop but I don't want to pull my C5 apart to pull the original bearing set out to find I don't have the right sized replacement.
« Reply #6 on: 05, November, 2009 - 17:57:26 »
just thought i'd mention, due to this thread i've bought one of these off Ebay -:
BIKE CRANK PEDAL ARM EXTRACTOR / FITTING TOOL NEW
(item no.) 390108005029 - Price: £4.99 + £2.50 postage
there were 4 left
regs
alan
C5-Ben
« Reply #7 on: 10, January, 2010 - 15:12:37 »
Does someone know if that Ebay Article    370308656318  could i use to remove the both pedals complete from the midlle gear bearing? Because I'm trying to dismantle the body completly.
Thx,
Ben
« Reply #8 on: 10, January, 2010 - 18:41:35 »
Thx,
Ben
It looks like the same as my one, so should be ok.
