Author Topic: pod lights  (Read 21325 times)
Re: pod lights
« Reply #30 on: 01, January, 2013 - 20:01:22 »
Hi Luke, the red cable loom has 9 wires connected to a 10 way connector.
You will not get a reply from Phil as he has left the C5 forum unfortunately but he left the POD replacement a freeware.
Re: pod lights
« Reply #31 on: 01, January, 2013 - 20:26:13 »
Thanks Lance  ;) ;)
Has any one made one of these ULA replacement modules before, if so approximately how long would it that my dad to do
Re: pod lights
« Reply #32 on: 01, January, 2013 - 20:56:00 »
I have bought a pod off eBay hopefully it will work :D :D :D :) ;)
Re: pod lights
« Reply #33 on: 02, January, 2013 - 18:47:14 »
The pod I bought is different to the picture on eBay according to the seller so it probably wont work :( :( >:( >:(
Re: pod lights
« Reply #34 on: 02, January, 2013 - 18:52:22 »
You were assured yesterday that it would work, why not wait and see.
Re: pod lights
« Reply #35 on: 04, January, 2013 - 15:02:31 »
It works!!! :) :) :)
But now the motor dose not work, dose any one know how to get round this problem
Re: pod lights
« Reply #36 on: 04, January, 2013 - 15:17:26 »
Also are the lights on the left hand side meant to flash when the c5 is not moving
Offline Dave.76
Re: pod lights
« Reply #37 on: 04, January, 2013 - 16:19:08 »
Hi Luke
Sorry to hear you are having problems. As far as I know, the left hand set of LEDs shouldn't flash when stationary. They certainly don't on my C5. As far as I am aware only the outer set of orange LEDs  on the left hand bank should stay on (not flashing) when the motor is not in use.
Re: pod lights
« Reply #38 on: 04, January, 2013 - 16:43:48 »
Year the 2 orange ones on the left hand side don't flash
Re: pod lights
« Reply #39 on: 04, January, 2013 - 16:45:21 »
May be it's flashing because the motor wont work. The motor works fine with the other pod but not with this one :-\ :-\
Offline dansretropod
    • www.c5owners.com
Re: pod lights
« Reply #40 on: 04, January, 2013 - 16:56:10 »
Looks like your new POD is just as broken as your old one.  Have you considered removing the POD and control box and just running your C5 from a relay?  It'll save you all the hassle/cost of dealing with faulty ULA chips.
Re: pod lights
« Reply #41 on: 04, January, 2013 - 17:07:46 »
I'll just see if I can get my dad to look at it tonight
Re: pod lights
« Reply #42 on: 04, January, 2013 - 17:20:04 »
Hi Luke- sounds like possibly another duff pod - the offer is still there if you want to stick them in the post to me I will see whats wrong with them for you - just cover the postage (£4 ish) - Marty
Re: pod lights
« Reply #43 on: 04, January, 2013 - 17:31:16 »
I'll talk to my dad when he gets home.
Can you swap ULA chips over between 2 pods :-\ :-\
    • www.c5owners.com
Re: pod lights
« Reply #44 on: 04, January, 2013 - 17:58:59 »
Yeah you can swap them over.  Just be careful to handle them correctly and protect them from static.
