Author Topic: FREE! C5 Serial Number Plate  (Read 23392 times)
« Reply #15 on: 22, October, 2008 - 03:03:25 »
All sorted ..........
Works fine ........... :D ;)
Thanks for all your help  ;)
toffeeboy
« Reply #16 on: 28, October, 2008 - 18:49:07 »
This is great - thank you very much.  I'll laminate mine when I get round to doing them!
Jonny
« Reply #17 on: 12, February, 2011 - 18:29:14 »
are you still making these?
« Reply #18 on: 12, February, 2011 - 20:41:33 »
It is a "D.I.Y" job, click on the link (also shown on page 1), save the document and alter the serial number to suit your own c5. Print it off and use some clear sticky back plastic to stick it on.
Jonny
« Reply #19 on: 13, February, 2011 - 00:53:28 »
ok thanks i'll have a go at that, do you know if there is any way to find out what your serial number is apart from the original sticker?
Offline peckishere
    • peckishere's Twitter
« Reply #20 on: 13, February, 2011 - 09:53:18 »
im in the same situation, I don't have my original sticker  :(
« Reply #21 on: 13, February, 2011 - 14:05:59 »
That the only id on the C5 ....
« Reply #22 on: 13, February, 2011 - 19:19:19 »
As Plod says, the sticker is the only "chassis plate" fitted - so if it's gone then sadly so is the record of your chassis number.
You could just have some fun with the replacement sticker, I bet very few people read the serial numbers anyway - why not add your name or anything else that takes your fancy. Could be a talking point at the meetings and events  ;).
Jonny
« Reply #23 on: 13, February, 2011 - 21:54:41 »
shall do, thanks  :)
