Author Topic: pod lights  (Read 21676 times)
Re: pod lights
« Reply #60 on: 05, January, 2013 - 20:07:54 »
Yes, my dad dose know about the electrics :) I'll get my dad to replace that resister ASAP
« Last Edit: 05, January, 2013 - 20:09:52 by Luke Salsbury »
Re: pod lights
« Reply #61 on: 05, January, 2013 - 20:09:13 »
I don't want my C5 to have more problems  ;)
Re: pod lights
« Reply #62 on: 05, January, 2013 - 21:19:19 »
Hi Luke - i'm guessing (without seeing it) your resistor that is burning out is R21 (10ohm) which , in my experience, can cause major damage to the ULA chip as it sits on the voltage regulation line - I would advice you to get your dad to change it before you use the C5 anymore - Marty
Re: pod lights
« Reply #63 on: 06, January, 2013 - 08:46:17 »
Yes it is the resister R21
Re: pod lights
« Reply #64 on: 06, January, 2013 - 08:50:01 »
My dad thinks if it dose burn out nothing will happen but I'll get him to read your post ::) ::) ::)
Re: pod lights
« Reply #65 on: 06, January, 2013 - 09:49:39 »
Do you not think Marty has a little more experience with how the POD works than your dad does?
Re: pod lights
« Reply #66 on: 06, January, 2013 - 11:16:42 »
I'm not saying that
Re: pod lights
« Reply #67 on: 06, January, 2013 - 11:18:43 »
That's why I am sending my pod to Marty so he can sort it out
Re: pod lights
« Reply #68 on: 08, January, 2013 - 20:43:36 »
Me and my dad have just opened the pod I got not that long ago. We found that that the 10ohm (R21) resister was unsoldered so we put that new resister in and soldered it both sides then we put it on the C5 now we are back to square one, the left hand side lights are flashing again. What is the effect on the C5 if you unsolder that resister, it was working fine when that was unsoldered :-\ :-\  :-\ :-\ :-\ :-\ :-\ :-\ :-\ :-\ :-\ :-\ :-\ :-\ :-\ :-\ :-\
« Last Edit: 09, January, 2013 - 06:52:07 by Luke Salsbury »
Re: pod lights
« Reply #69 on: 09, January, 2013 - 06:43:40 »
And also the motor has stoped
Re: pod lights
« Reply #70 on: 09, January, 2013 - 16:09:47 »
Can I still use the C5 without that resister
Re: pod lights
« Reply #71 on: 10, January, 2013 - 19:32:44 »
I'm sorry that I keep re posting my self but if I can get away with taking this resister out of the circuit board in the pod so the C5 works I will do so :)
Re: pod lights
« Reply #72 on: 10, January, 2013 - 19:55:50 »
Have you sent a POD off to Marty?
Re: pod lights
« Reply #73 on: 10, January, 2013 - 23:05:12 »
Hi Luke,
Re-read reply 62 before you cause any fatal damage. Don't look for an easy way out of something that has no easy way out of. If you KILL the ULA THAT'S IT.
Re: pod lights
« Reply #74 on: 11, January, 2013 - 07:27:39 »
Not quite yet. I need to get Marty's Email address's first, I'll be Emailing him soon
