Author Topic: Wanted (never know unless you try)  (Read 4324 times)
Offline Ant
« on: 09, May, 2012 - 22:45:12 »
Hi everybody
I was just wondering if anybody had any of the following spares they would like to sell.
C5 seat cushion ?????
Rear view mirrors ????
Rubber gromet things where the high vis mast would go ??????
Mudflaps ????????
High hopes but always worth a try.
Ant.
Re: Wanted (never know unless you try)
« Reply #1 on: 09, May, 2012 - 23:04:31 »
Hi Chas has the mud flaps (not original) but you cannot see the difference.
« Reply #2 on: 10, May, 2012 - 09:44:33 »
Hi, if you cannot obtain a genuine seat pad, I sell a 3mm coated black foam from which you could make seat pads @ £7.20 per linear metre (that is 1.5m wide), plus postage. I also sell self-adhesive hook & loop(Velcro is a brand name for this type of thing) @ £2.40 per metre for the pair.
Offline Ant
« Reply #3 on: 10, May, 2012 - 19:19:44 »
I like the idea of trying to make a seat cushion, has anybody tried it ???????
there must be a way, maybe by heating the foam and molding it into shape somehow hmmmm ????
« Reply #4 on: 10, May, 2012 - 19:23:04 »
Hi there Ant if you want any mudflaps please email me ..bye Chas
marra
« Reply #5 on: 10, May, 2012 - 20:55:57 »
 Foam that was used was Cold-cure molded foam. this cannot be reformed. You would need a pressure mould to make more and that would be very costly. From my experience and others round these parts the cushion just caused trousers to ride up around somewhere  :-\  .. got a little sweaty in summer . If its uncomfortable, just get a small tapestry cushion for your butt. ..... also cheaper
Offline Ant
« Reply #6 on: 14, May, 2012 - 19:31:28 »
Ordered the mudflaps last night on ebay am i right in thinking these are from you chas ????
« Reply #7 on: 14, May, 2012 - 19:49:35 »
They sure are .....   ;)
« Reply #8 on: 15, May, 2012 - 09:42:58 »
Yes they are ......
Offline Ant
« Reply #9 on: 15, May, 2012 - 18:35:37 »
Got them today when i got in from work, the looky great Chas, then realized i havent got a drill arrrrhhhhh.
Ill try the neighbor ha ha
« Reply #10 on: 15, May, 2012 - 20:10:59 »
Hi there Ant regarding the mud flaps if you had looked at the Chas section on  the forum you would have got them cheaper ...bye and thanks Chas
Offline Ant
« Reply #11 on: 15, May, 2012 - 20:31:33 »
Ahhh no way i didn't know that existed  :'(
Offline Ant
« Reply #12 on: 15, May, 2012 - 20:32:37 »
Found it !!!!!
« Reply #13 on: 16, May, 2012 - 08:14:20 »
Ok Ant if there is anything on the Chas section you want just let me know ....Bye Chas
