hi there.....having problems in getting the bearing off the rear axell...and didnt want to be to hard on it
so can any one help....how does it come off :-\.....the big hammer iching to be used...lol
many thanks the plumber ;D
Best to use a 'puller' if you can get hold of one.
Regards Marty
like Umpa says - use a proper puller.
The axle is hollow so could get damaged if you start using big hammers
All mine get done by a mate who works in a local garage using a proper machine - saves a lot of hassle. There must be a garage local to you that could help ?
Quote from: BooBoo on 29, June, 2010 - 12:04:54
?????? - We are not one and the same even though we have not been seen in public together for a while ! :D
Sorry Marty, a definate case of "night duty-itis" - (joys of being woken up by the noise of a chainsaw) :o I must remember to keep away from the keyboard until I'm properly awake ;D
...in my defence I had just been reading a posting by umpa ;)
Plummer - this is a piccie of the axle assembly;
(http://i74.photobucket.com/albums/i257/1stbooboo/c5help006.jpg)
Am I right in thinking you want to change the bearing shown ?
If so, it just slides off when using a proper bearing press - the last one I had done by my mate was two years ago so I'm happy to be corrected. I don't have any memories of it causing us any grief , seemed quite straight forward ;) . We didn't encounter any snags such as having to remove those components on the end.
many thanks to you all...........got bearing off ;D....i didnt know how to get that bush off,but it pressed on...many thanks for you help :)
the plumber
