C5 Help => C5 Support => Topic started by: Karl on 05, September, 2010 - 20:58:10
Title: Needs a proper greasing..
Post by: Karl on 05, September, 2010 - 20:58:10
Here are some pictures showing the amount of grease found in a set of c5 rear wheel bearings. The c5 was removed ,unused, from the box by myself.
  (http://i74.photobucket.com/albums/i257/1stbooboo/c5stuff002.jpg)
They weren't exactly generous with the grease on that Sinclair production line !
Title: Re: Needs a proper greasing..
Post by: giles on 06, September, 2010 - 07:12:03
Would copper grease do or does it have to be standard grease?
Giles
Post by: Karl on 06, September, 2010 - 08:12:03
Quote from: giles on  06, September, 2010  - 07:12:03
Giles
I've never tried copper grease, you could always give it a go  ;)
Post by: marra on 06, September, 2010 - 09:55:29
Giles
No, Copper grease is for lubricating high temp parts such as break calipers, rear pads , exhaust manifaulds and wheel studs. its NOT for friction materials. copper grease when heated up forms a protective barrier/ film that will not was off under normal intended use.copper grease is an antiseize compound capable of withstanding high temperatures but its lubrication properties aren't the best. just use a universal grease , or best for bearings i would say Molly.
sure someone will say im wrong though. :P
