Hi
I'm a new member of this forum and own a C5 now for a year. I prefer 'box standard' bud it has to be reliable/ work up to standard. So some mods i'm working on now, pictures will follow.
-standard ligthing, no serious licht output.
-front now equiped with: http://www.immers.info/Webwinkel-Product-1954177/12v-T10-25-SMD-Wit-(175lumen).html (http://www.immers.info/Webwinkel-Product-1954177/12v-T10-25-SMD-Wit-(175lumen).html) Maybe it's a bit to much, it's unbelievable bright.
-rear light: http://www.immers.info/Webwinkel-Product-1842600/12volt-Angel-eyes-ringen-Upgrade-LEDs.html (http://www.immers.info/Webwinkel-Product-1842600/12volt-Angel-eyes-ringen-Upgrade-LEDs.html)
-brake light:http://www.immers.info/Webwinkel-Product-1958925/12v-T10-8-SMD-Wit-(56lumen).html (http://www.immers.info/Webwinkel-Product-1958925/12v-T10-8-SMD-Wit-(56lumen).html)
Fitting off a sturmy-archer 3-gear hub, it's almost in, I hope to make a test drive early next week .
Fitting of trip computer: done
The electrics and drive line seems to work fine, the pod isn't working, all leds are a bit glowing up. We dit some testing, swapping. I think I leave it this way and when the electrics or gears starting to fail I go for a radical upgrade to a chinese ebike drive system (for use at 24v volts).
Wow, fantastic looking bulbs!
I fitted something similar to the tail light of my motorbike last year but it only had 5 LEDs in it, not 25! Would be great to see a photo of them in your C5.
C.
sounds awesome, any chance of some pictures of how you are doing the gearing system? sounds like a good mod
Sounds good, any pictures ? Welcome to the forum :)
