C5Alive General Category => C5 Chatroom => Topic started by: Retro Andy on 08, May, 2011 - 22:35:54
Title: C5 Restoration for John
Post by: Retro Andy on 08, May, 2011 - 22:35:54
Hi all, I recently meet a man called John who lives about 15 miles from me in Hunstanton and has owed his C5 for a long time, but it has'nt been used for about 4 years, I am going to strip it down, clean/restore it for him. Here are a few pictures before I start, hopefully John will intruduce himself on the forum soon and be able to get out and about in his C5 again,
P.S Do you like the tent, perfect for a C5 ?
(http://i292.photobucket.com/albums/mm29/retroandy/370.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/371.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/372.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/375.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/374.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/376.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/373.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/377.jpg)
Will post more pictures as I go.
Title: Re: C5 Restoration for John
Post by: John Raj on 09, May, 2011 - 08:55:33
Hi Andy - the pictures are great and I like the cover.  Where did you get that from.  It is ideal for the C5 and it keeps it covered.  I think a wooden platform on the floor would be nice to have the tires of the grass in the event if it rains heavilly etc. -  John
Post by: Karl on 09, May, 2011 - 09:20:12
Doesn't look too bad, a bit of elbow grease and some painting and that will come up a treat  8).
Not sure about painting the motor black though..and cutting the wires to remove the motor is criminal  :o
Post by: Retro Andy on 09, May, 2011 - 20:59:32
The tent would'nt be a long time store for a C5, this is a small kitchen tent used when camping from argos, but comes in handy for lots of things like this, I put it up as it was ment to rain yesterday and I like working outside in the fresh air and daylight, here are a couple more pictures
(http://i292.photobucket.com/albums/mm29/retroandy/001-6.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/002-5.jpg)
Post by: Karl on 09, May, 2011 - 22:01:18
Looks like you're winning...no nasty surprises so far ?  Good to see the handle bar stem and pedal crank came out ok  8)
Post by: PLOD11 on 09, May, 2011 - 22:05:37
This is what i used to temporary store my C5 one winter, perfect fit for a C5  ;D
(http://i790.photobucket.com/albums/yy186/PLOD11/DSCF9454.jpg)
(http://i790.photobucket.com/albums/yy186/PLOD11/DSCF9448.jpg)
Post by: vanpeebles on 10, May, 2011 - 09:22:39
Quote from: Retro Andy on  09, May, 2011  - 20:59:32
I think you just like building a base  ;D
Post by: tomsa on 11, May, 2011 - 01:34:32
Doesn't look too bad, a bit of elbow grease and some painting and that will come up a treat. ;D
Not sure about painting the motor black though..and cutting the wires to remove the motor is criminal :D
Post by: Retro Andy on 11, May, 2011 - 05:57:00
Is their an echo  ;D
Post by: Retro Andy on 11, May, 2011 - 06:04:17
Been busy stripping down John's C5, and know its onto the big clean up before re-assemble and testing, not sure about the condition of the hub bearing in the left rear wheel, will it be alright ?
(http://i292.photobucket.com/albums/mm29/retroandy/001-7.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/002-6.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/003-5.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/004-5.jpg)
Post by: Retro Andy on 13, May, 2011 - 06:09:16
Now started clean the frame up ready for painting, new tyres, tubes, brake blocks, brake cable, decals, C5 Alive wiring and a few small bits ordered and on the way, will update pictures shortly.
Post by: Retro Andy on 20, May, 2011 - 06:26:37
Frame and forks cleaned and sprayed, a nice lot of new parts and things are coming along.
(http://i292.photobucket.com/albums/mm29/retroandy/012-3.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/013-4.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/014-3.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/015-2.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/016-2.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/017-2.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/018-2.jpg)
Post by: PLOD11 on 20, May, 2011 - 10:56:46
Looking good !!! ;D
Post by: radiomarty on 20, May, 2011 - 14:48:15
Coming on well Andy - keep the photo's coming
Post by: Karl on 20, May, 2011 - 21:35:55
The chassis came up nice, looks like your winning  8)
Post by: Lancealot on 21, May, 2011 - 09:31:32
Starting to take shape, keep going good work, mate.
Post by: John Raj on 21, May, 2011 - 12:40:07
Nice to see the car coming up nice.  Waiting to see it totally completed.
Post by: Retro Andy on 25, May, 2011 - 06:20:03
Almost done John, everything has been stripped, cleaned, greased etc, electrics checked, hope everything works fine when all back together.
(http://i292.photobucket.com/albums/mm29/retroandy/002-7.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/001-8.jpg)
Post by: radiomarty on 25, May, 2011 - 13:05:26
Always great to see them back to there former glory - great job Andy !! - look forward to seeing the finished article ! :)
Post by: C5 ENTHUSIAST + RESTORER on 25, May, 2011 - 16:05:57
Well done looking great ....keep us posted .Chas
Post by: Retro Andy on 25, May, 2011 - 21:51:38
I have been testing everything before finishing putting everything back together again and have found that a couple of extra parts are needed, sorted out these with Karl earlier and will soon be here, then I can finish it all off and go for a test run.
Post by: Retro Andy on 04, June, 2011 - 20:57:18
Have been away for the week camping, but been finishing off John's C5 today, I have come up against two issue's, the first is that when the motor is running with the wheel off the ground all works fine, but when you try it with the wheel on the ground, it make a terrible noise when trying to turn and the belt comes off and the second fault is the pod isn't lighting up correct up the left
display, I think Karl will bring along some spares next week and help get it up and running  :)
Will add some pictures tomorrow, I think it has come up well.
Post by: PLOD11 on 04, June, 2011 - 23:29:31
Have you had the motor / gearbox apart ?  What condition was it in ?
Post by: Retro Andy on 05, June, 2011 - 07:35:10
Yes, had the motor/gearbox apart, cleaned and greased gearbox etc, didn't notice anything wrong, but I plan on taking the motor out and having another look.
Post by: Lancealot on 05, June, 2011 - 09:59:46
Hi Retro Andy,
I found the same fault with a motor I had, it may be the same, so worth a look.
Coming off the motor brushes are two braided wires that then attach to the outer connector. This in turn is then attached to the RED & BLACK power cables. I found one of the braided wires not connected. This gave similar symptoms you are having. I used an old back end of a motor housing / brushes that I had spare but if this is your problem you should get spare from Karl.
Hope this helps
Post by: Retro Andy on 05, June, 2011 - 11:49:15
Many thanks, you might be onto something with that, plus I think I have a spare end from when I restored mine, will try that next.
Post by: Retro Andy on 05, June, 2011 - 12:08:45
Here are the pictures I took this morning, just need to sort the two issue's and all done.
(http://i292.photobucket.com/albums/mm29/retroandy/020-3.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/019-3.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/018-3.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/017-3.jpg)
(http://i292.photobucket.com/albums/mm29/retroandy/016-3.jpg)
Post by: Lancealot on 05, June, 2011 - 13:13:51
Nice one Retro Andy, I am sure John will be very happy with his refurbed C5.
John enjoy!!!!!! ;D ;D ;D ;D ;D ;D ;D ;D ;D
Post by: PLOD11 on 05, June, 2011 - 17:44:54
All ready for the Royal Run   8)
Post by: PLOD11 on 05, June, 2011 - 17:47:18
Has that spider been refurbed as well ??  :D
Post by: Retro Andy on 08, June, 2011 - 07:38:57
I think that the motor issue maybe with the brushes, as the negitive one was very loose (broken) and could be the cause, I have tryed to swap with my spare one, but that broke trying to remove it (corroded in) even soaked it in wd40, so can you please bring along some spares Karl on Sunday, many thanks.
Post by: Karl on 08, June, 2011 - 08:54:13
No worries mate  :)
Post by: Retro Andy on 08, June, 2011 - 09:17:11
Many thanks.  :)
Post by: Retro Andy on 14, June, 2011 - 21:03:23
Many thanks to Karl bringing along the solution to the problem with the motor, a replacement motor housing and brushes done the trick, wired it into the control box last night and took it for its first run, all went well.  :)
