Hello,
So I have a column to make the front/noise of the C5fix and that he doesn't wobble so much.
(http://i1245.photobucket.com/albums/gg595/Thor069/2012-03-25163618.jpg)
It's self made from Wood and I will use this to fix on it a control panel.
But first I will look to put a gear in the chain while the pedaling is too bad, high rhythm for me.
Best regards.
Thorsten
Hi Thor,
I wonder, won't this wooden post create more noise then it reduces? The trembling of the body is transmitted to the chainspace witch could work as a resonance case. Don't know. Let us know how it works out for you.
greetz
Hi there just a question are the black plastic washers in place of that hold the pod in place .....bye Chas
Quote from: C5 ENTHUSIAST + RESTORER on 17, April, 2012 - 14:10:45
Hi Chas, I try to figure this one out, aren't the black plastic washers that hold the pod in place, white?
bye Frank
Hi there Frank ..The washers are black They fit between the pod and the white plugs underneath the front ...Take a look on my site on the forum (The Chas section) And look at items that are for sale ... Bye Chas
