What a find, I lost one of my boot securing clips when on the Royal Run route last year and got a replacement, and I have been running about 3 miles along this route 2 or 3 times a week since July trying to loose a few pounds and get a little fitter, and to my amazement I found it right in the middle of the path after the grass had been cut along the edges, and its not damaged, so I now have a spare :)
Wow Andy that was a lucky find - on a level with Minidaz finding his chain link !!! :) :)
What are the chances in that ::)
1 in a 1,000,000 :P
Your luck is in matie ...go out and buy that winning lottery ticket :P
Only to lose it, :o :o then find it again after the claim limitation. 8) 8)
Quote from: BooBoo on 19, November, 2012 - 10:08:21
We did !!! :) :) :) But did'nt even get one number :'(
You should be ashamed of yourself. :P
Quote from: Retro Andy on 19, November, 2012 - 17:42:22
You never do with the lottery >:( >:(
Want to pop over here and try your luck at finding the little plastic & rubber grommet from the mast hole that I lost? :p
When was this ???
Andy could lose some more weight running around the area you lost it :D :D
I'm only half way to my goal weight and not been running for a few weeks as had man flu, its been raining or other things, I do like a short run on a cold frosty morning (I never though I was someone who would enjoy running, but when the weight starts to come off you enjoy the results) two stone almost lost and two to go.
Quote from: Retro Andy on 20, November, 2012 - 06:38:46
That's one way to make your c5 go faster.. ;)
Hairy Dieters Cookbook, that's all you need :)
I lost 4.5st in 2 years but couldnt shift the last stone. 6 weeks on that diet and I lost it, and it's real food, not rabbit food :p
Can't say it's helped me go any faster or uphill any easier though :D
Oh well at least your are skinnier :)
QuoteCan't say it's helped me go any faster or uphill any easier though
Glad to hear that as I want to add some weight.
NO not to myself but to the C5. ::)
Quote from: mhurt on 23, November, 2012 - 12:28:11
..it should have improved the range you get out of the batteries on your c5 8)
