C5alive Marketplace => The Chas section => Topic started by: C5 ENTHUSIAST + RESTORER on 26, January, 2013 - 13:25:22
Title: MY NEXT RESTORATION STARTED
Post by: C5 ENTHUSIAST + RESTORER on 26, January, 2013 - 13:25:22
Hi all just started my next restoration ...Body stripped down and left out in the snow ....all other Parts inside
(http://i992.photobucket.com/albums/af46/jordan8_2009/6-C5CHASSIBODY.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/7-IMGP2868.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/1-IMGP2865.jpg)
Chassis cleaned sanded and sprayed ...
(http://i992.photobucket.com/albums/af46/jordan8_2009/5-IMGP2859.jpg)
As you can see there is a lot of work to do on it .But no problem
Title: Re: MY NEXT RESTORATION STARTED
Post by: Luke S on 26, January, 2013 - 15:40:07
Where did you get this c5
Post by: danny7147 on 26, January, 2013 - 15:42:45
How much do you charge for restored ones Chas? I'm going to be in the market for one in a few weeks time.
Post by: C5 ENTHUSIAST + RESTORER on 26, January, 2013 - 18:56:27
Hi more photo's .
The back axle is not bent its just the looks like it ..
(http://i992.photobucket.com/albums/af46/jordan8_2009/3-IMGP2871.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/2-IMGP2870.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/1-IMGP2869.jpg)
Post by: danny7147 on 26, January, 2013 - 19:01:13
Looking good! Are you doing this one to keep or sell?
Post by: C5 ENTHUSIAST + RESTORER on 26, January, 2013 - 19:12:01
Hi there it will for sale I have no more room to store anymore ..
Post by: danny7147 on 26, January, 2013 - 19:46:23
Pending the price, pencil me in for it! Do you know a price yet? I've been given my wife's permission to get another one 8)
Post by: C5 ENTHUSIAST + RESTORER on 26, January, 2013 - 20:04:23
Hi there Danny will let you know later ..
Hi there what you would get is a  totally restored the C5 ....e.g.. a complete strip down the body cleaned + the front / back wheel trims cleaned .
All parts cleaned and sprayed (chassis / back wheel arch / front forks / pedals / crank / brake levers .
Wiring / Pod / Control Box checked out .
Motor /gearbox stripped down checked greased and replace items that are faulty or worn
Carbon Brushes checked replaced if  worn down
All metal parts cleaned and greased
New Tyres /inner tubes fitted all round
New Mud flaps fitted
New Safety cables fitted .
Will not damage the Pod / Control Box if connected the wrong way round and allow a larger battery to be used
New Battery support straps fitted
New Stickers fitted on the side +front and back wheel
New Front brake callipers fitted + brake cables for the front/back brakes
Also all bearings replaced if warn refitted and  greased
New 18 mm belt
New Chain fitted
New LED bulbs fitted (front/back)
New Washers / nuts / bolts
New Chain tensioner fitted with side guides on
BATTERY NOT INCLUDED UNLESS YOU WANT ME TO BUY ONE FOR YOU .
NO MIRRORS
NO INDICATORS
NO HORN
Post by: danny7147 on 26, January, 2013 - 20:29:42
Sounds fantastic! Keep me updated with it if you can Chas, but sounds like exactly what I'm looking for! I've got mirrors and an indicator set so no problem there!
Post by: C5 ENTHUSIAST + RESTORER on 26, January, 2013 - 20:55:27
Ok just keep looking on the forum ...
Post by: danny7147 on 26, January, 2013 - 21:19:37
No problem :)
Post by: Ton C5 on 27, January, 2013 - 10:49:10
Hi Chas,
i am about to start a restoration of my own and i am wandering what you are using to spray the frame?
i was thinking about a powder-coat but the price exceeds my budget. the next option would be zinc spray or ....
who knows what is best ?
Ton
Post by: kamilb1998 on 27, January, 2013 - 12:12:26
Quote from: Ton C5 on  27, January, 2013  - 10:49:10
Hi Chas,
Ton
I use my C5 everyday and have re-sprayed the chassis with just normal off the shelf paint and it's holding up fine - even though the C5 often gets wet.
Post by: Lancealot on 27, January, 2013 - 12:50:26
Most people get the chassis sand blasted or wire brushed. Then 2 coats of car spray undercoat, 2 coats of car spay gloss and then 1 or 2 coats of car spay laquer.
Post by: danny7147 on 27, January, 2013 - 17:08:08
Hi Chas,
Ton
I find it interesting you think that because I used to think the same! I've restored about 30 bicycles and the last 10 I had powder coated.
I called a couple of local places, and to get the frame and forks blasted and powder coated black cost me £60 the first time on the assurance that it was a cheap price. The next couple of bikes were the same, but then one day I read about a powder coat chrome effect, my regular company couldn't do it so I ended up ringing about 15 firms. I found one about 30 miles away, and when I asked the cost of doing a bike frame black they said "Oh, £15?"...
I've used them ever since with great results! My point is with powder coating, don't call two companies and assume you know what it costs... it's as open to price change as anything else is.
Powder coating' s great, but there are three important points to keep in mind...
1 - Think carefully about the finish. While not as important as a bike frame as it's hidden, gloss comes up a LOT shinier than paint, satin is like regular gloss, and even matt has a shine to it. One of the biggest mistakes I made was doing a 1940's bike in gloss thinking it would look New, because even though it does, it looks 'too' new, and nowhere near authentic.
2 - It's not a rust proofed. None of my collection are kept outside so it doesn't really affect my collection, but make sure you pay the extra for a primer for a bit of added protection.That extra £5 will make it last a LOT longer.
3 - Powder coating' s stronger than you can imagine, and once on is seriously hard to remove. Make sure you get it the right colour/finish first time because a second chance will open up a whole new set of problems  ::)
Post by: C5 ENTHUSIAST + RESTORER on 27, January, 2013 - 17:21:38
Some more photo's
(http://i992.photobucket.com/albums/af46/jordan8_2009/2-IMGP2873.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/3-IMGP2874.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/4-IMGP2875.jpg)
Post by: Ton C5 on 27, January, 2013 - 19:16:58
15 pounds is not bad, is that including sandblasting ?
i ve got 2 prices 220  and 250 euro and that is with blasting
Post by: danny7147 on 27, January, 2013 - 20:34:12
Yes, complete with primer! I don't know the prices in Europe, but it really is worth calling as many companies as you can because there will always be a cheap one!
Post by: Karl on 28, January, 2013 - 13:59:00
I've yet to have any c5 chassis powder coated but looking at the superb job done on electricDaves MGF sub frames I'm going to experiment and have the next one done. Thanks for the heads up on rust proofing !
All the refurbed c5's I've done to date have had a similar treatment as mentioned by Lance. Shotblasted first, then cleaned, then several coats of primer followed by several top coats and finally a couple of coats of laquer. The paint I'm happiest with for use on the c5 chassis is the rattle can stuff for spraying steel wheels silver on cars. It is sold as being chip resistant and if you bulk buy it works out quite cheap per can. The chassis do tend to come up quite nice after this process  8)
Post by: danny7147 on 28, January, 2013 - 14:43:26
When I at chance I'll add a couple of photos of things. One shows how good powder coating can be, the other how bad!
The 1940 bike I've got looks incredible, shining black paint, glimmering chrome, but a bit too 'bee's, although it does show the quality that can be achieved. The other is an old helmet that was done in satin powder coat. It looks terrible because it's far too shiny and shows every little bit of pitting in the metal. That incidentally is another thing, if it's not a smooth surface you can't fill and sand like you can with paint!
But for a chassis it would be perfect... finish doesn't really matter as it's hidden, and it's a much, much harder finish meaning less scratches and very little maintenance to keep it looking immaculate! Pros and cons  ::)
Post by: C5 ENTHUSIAST + RESTORER on 28, January, 2013 - 21:49:27
Ok here are some more photo's
(http://i992.photobucket.com/albums/af46/jordan8_2009/1-IMGP2877.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/2-IMGP2878.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/3-IMGP2879.jpg)
Just started to clean the body ..
(http://i992.photobucket.com/albums/af46/jordan8_2009/6-IMGP2882.jpg)
Had enough of the body so started to repair the wiring harness
(http://i992.photobucket.com/albums/af46/jordan8_2009/7-IMGP2884.jpg)
Post by: C5 ENTHUSIAST + RESTORER on 29, January, 2013 - 15:25:24
Cleaned the body ,but it will have another clean up later on ...
(http://i992.photobucket.com/albums/af46/jordan8_2009/3-IMGP2891.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/4-IMGP2892.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/2-IMGP2890.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/1-IMGP2889.jpg)
Post by: Luke S on 29, January, 2013 - 15:51:26
looking good
Post by: C5 ENTHUSIAST + RESTORER on 29, January, 2013 - 18:33:01
Thanks ....
(http://i992.photobucket.com/albums/af46/jordan8_2009/2-IMGP2896.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/3-IMGP2897.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/1-IMGP2895.jpg)
Post by: C5 ENTHUSIAST + RESTORER on 30, January, 2013 - 17:19:09
Just started to check out the electronics ,Had a few problems with bad contacts  on the connectors  but now all checked out ok ...
Take a look ....
The motor is there just to check out the system...Just needs to be stripped down cleaned greased  restored
(http://i992.photobucket.com/albums/af46/jordan8_2009/1-IMGP2902.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/3-IMGP2905.jpg)
Post by: Luke S on 31, January, 2013 - 07:12:09
You are doing that quick
Post by: C5 ENTHUSIAST + RESTORER on 31, January, 2013 - 09:23:17
Just replacing the bulbs .
As you can see there is a difference in them .The first is the original and the 2nd is a LED .Both bulbs are the same wattage ...5 WATT
(http://i992.photobucket.com/albums/af46/jordan8_2009/1-IMGP2899.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/2-IMGP2900.jpg)
Post by: C5 ENTHUSIAST + RESTORER on 31, January, 2013 - 14:06:57
More photos. Started on the motor
(http://i992.photobucket.com/albums/af46/jordan8_2009/01-IMGP2906.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/02-IMGP2907.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/03-IMGP2908.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/04-IMGP2909.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/05-IMGP2910.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/06-IMGP2911.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/07-IMGP2912.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/08-IMGP2913.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/09-IMGP2914.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/10-IMGP2915.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/11-IMGP2916.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/12-IMGP2917.jpg)
Post by: Luke S on 31, January, 2013 - 16:22:57
How's the pod working
Post by: C5 ENTHUSIAST + RESTORER on 31, January, 2013 - 17:47:59
The pod/control box are working at the moment showing the current when the motor turns .But I need to take it on a run to check out the voltage to see if it drops as it should
But not quiet ready for a run yet  ...
The wiring is not tidy yet due to the fact that I have not been out in it yet but if all is ok I will tidy it up ..
And here are some more photo's
(http://i992.photobucket.com/albums/af46/jordan8_2009/13-IMGP2918.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/14-IMGP2919.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/16-IMGP2922.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/15-IMGP2921.jpg)
Post by: Luke S on 31, January, 2013 - 18:52:21
Dose not take you long  :o :o
Post by: Lancealot on 31, January, 2013 - 19:24:45
Hi Chas like normal looking very good. Keep going mate nice one.
Post by: Ton C5 on 31, January, 2013 - 19:55:59
Wow, youre quick and the result is looking good .
wish i could work on my c5 inside, but my wife would would kill me  :(
well not kill but i probably have to sleep on the coach  ;)
Post by: C5 ENTHUSIAST + RESTORER on 31, January, 2013 - 21:06:25
Hi there thanks for the comments ... I only work on it when she's out .....
Post by: C5 ENTHUSIAST + RESTORER on 01, February, 2013 - 14:48:51
Hi just fitted some mud flaps .Also side and front stickers fitted ..
(http://i992.photobucket.com/albums/af46/jordan8_2009/1-IMGP2926.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/2-IMGP2923.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/3-IMGP2925.jpg)
Post by: C5 ENTHUSIAST + RESTORER on 01, February, 2013 - 18:31:23
Hi here is the front light with a LED bulb in it .
(http://i992.photobucket.com/albums/af46/jordan8_2009/5-IMGP2935.jpg)
The boot insert was in a mess so I used one that I made earlier ..Take  a look .
(http://i992.photobucket.com/albums/af46/jordan8_2009/2-IMGP2937.jpg)
The next thing will be to clean te boot ...
(http://i992.photobucket.com/albums/af46/jordan8_2009/7-IMGP2940.jpg)
Post by: C5 ENTHUSIAST + RESTORER on 02, February, 2013 - 16:42:37
MY NEXT RESTORATION STARTED .Has now been finished take a look
Now open to offers
(http://i992.photobucket.com/albums/af46/jordan8_2009/4-IMGP2944.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/3-IMGP2943.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/2-IMGP2942.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/1-IMGP2941.jpg)
Post by: Phoenix on 02, February, 2013 - 17:49:39
Wow what a difference, looks fantastic
Post by: Luke S on 02, February, 2013 - 19:06:34
Back from the dead 8) 8)
Post by: Dave.76 on 02, February, 2013 - 21:51:43
Excellent work Chas, as always  :) and fast too.
Post by: Luke S on 03, February, 2013 - 12:26:31
How many C5's have you done up Chas
Post by: C5 ENTHUSIAST + RESTORER on 03, February, 2013 - 14:39:06
Not sure maybe 20
Post by: Lancealot on 03, February, 2013 - 19:35:19
Nice C5 Chas, Just got to get rid of the tupaware lids..... ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;)
Post by: Luke S on 03, February, 2013 - 20:24:26
Quote from: C5 ENTHUSIAST + RESTORER on  03, February, 2013  - 14:39:06
Not sure maybe 20
Good number
Post by: Luke S on 07, February, 2013 - 16:05:45
Is it just me but when I bought my C5 the pod did not work and when every one else buys one the pod is working  :-\ :-\ :-\
Post by: Luke S on 07, February, 2013 - 16:07:05
On average Chas how long do you take on restoring a c5
Post by: C5 ENTHUSIAST + RESTORER on 07, February, 2013 - 16:47:32
Hi there on average it takes about 2 to 3 weeks from start to finish
Post by: Luke S on 07, February, 2013 - 16:57:35
Quote from: C5 ENTHUSIAST + RESTORER on  07, February, 2013  - 16:47:32
That's quite quick
Post by: C5 ENTHUSIAST + RESTORER on 07, February, 2013 - 17:07:01
But it takes a lot longer this time of the year ...
Post by: Luke S on 07, February, 2013 - 17:32:19
Quote from: C5 ENTHUSIAST + RESTORER on  07, February, 2013  - 17:07:01
But it's a lot longer this time of the year ...
I can see why  ::) ::)
Post by: C5 ENTHUSIAST + RESTORER on 10, February, 2013 - 18:40:46
Just uploaded the C5 for sale on Ebay
Post by: Luke S on 10, February, 2013 - 19:08:11
Like too buy it but 2 draw backs
1. My dad won't let me
2. You are too far away
Post by: Luke S on 10, February, 2013 - 19:10:11
Your C5 is in better condition than the other C5 on eBay and you have started bidding at 99p whilst he has at £550  :-\ :-\
Post by: pso-buzz on 10, February, 2013 - 19:13:57
Hi Chas
Isn't that a bit risky putting it on without a reserve or start price?
It must stand you at a few pounds with the new tyres etc.
Simon
Post by: C5 ENTHUSIAST + RESTORER on 10, February, 2013 - 19:27:59
Thanks it has cost a bit will see how it goes plenty of  time yet
Post by: pso-buzz on 10, February, 2013 - 19:54:04
I see the bids are coming in already.
Good luck
Post by: Luke S on 10, February, 2013 - 20:11:38
£46 all ready  :o
Post by: Luke S on 10, February, 2013 - 20:46:17
Quote from: pso-buzz on  10, February, 2013  - 19:13:57
Hi Chas
Simon
I don't think he'll need a reserve as it is £102  :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o
Post by: Luke S on 20, February, 2013 - 19:48:32
How much did it sell for Chas  :-\ :-\
Post by: Luke S on 20, February, 2013 - 19:56:18
The last time I saw it the current bib was something like £335
Post by: pso-buzz on 20, February, 2013 - 19:57:54
£510.  Sounds like a good price.
Hope it covered your costs and time.
Post by: Luke S on 20, February, 2013 - 20:00:58
Quote from: pso-buzz on  20, February, 2013  - 19:57:54
£510  :o :o :o :o
A very good price for it  8) 8) 8)
Post by: C5 ENTHUSIAST + RESTORER on 21, February, 2013 - 08:22:48
Thanks I was very pleased with the price ..Now it's time to get cracking with the Sturmey Archer 3 speed conversion C5 ..
