Today when disassembling the rear wheel for inspection I found out the big drivewheel has some small cracks.
(http://i1300.photobucket.com/albums/ag99/gertk64/2013-05-11155840_zps42cefe54.jpg)
I recognize this problem from several consumer electronics stuff (like CD/DVD player drive motors) where sometime the small gear on the motor develops a small hairline crack and the gears do not mesh properly anymore.
(http://i1300.photobucket.com/albums/ag99/gertk64/2013-05-11155857_zps47011d1b.jpg)
In this case the cracks are not all the way through so it is still sitting tight but I wanted to stop the cracks from growing bigger. The smaller crack was quickly filled with industrial cyanoacrylate. To make the cyanoacrylate fill the larger gap I filled it with an aggregate (some plexiglas filings left on my workbench..) and soaked it in cyanoacrylate.
Photo later on..
I hope this way the wheel is strong enough again.
Looking forward to seeing the results of this as it is a very common failure with this component - Marty
Marra is making metal versions of these, I'm sure theres also scope to run these through a 3d printer
Will be surprised if a 3D layer printed drivewheel will have the shear stregth to withstand the torque at lock.
Aye :D But if you never try, you will never find out ;D If it disintegrates I'll use a metal one
Hi there Dan I think that if we all check the large drive wheel we will find that most of them will have small cracks in them ....Chas
