she has died this time i put the battery on lights came on but no pod lights then tried to go and not evan the relay clicked i have checked the fuses and as much of the wirirng as i can everything look ok apart from pod lights need to get her back on the road asap as gotta get to work and i am missing riding on the ice
sorry to hear you're having a few snags mate
might it be worth posting your control box and pod off to Martin for a check over ?
it would at least help eliminate what the problem is.
I did have the same thing happen to me once and it turned out to be corroded connection's on the pod.
After I cleaned them up,all was well.
I know its a long shot,but worth a try.
Good luck.
i thought the same thing it was one of the first things i tried cheers will hope get some time over the weekend to potter around
have you sorted it out yet ? - would like to know what it was
Cheers
ian
well well well after weeks of crap working 70 hours a week i will finaly get the time this weekend to give it a go i f****g hate the NHS
(swearing amended by Karl...might be youngsters viewing )
right you have had long enough. ;D
Have you fixed it yet ?
no chance will have to send it back to martin when i get some cash need it for the spring and i am fed up of buses thay are crap
